Profiling DCGan Tutorial Spins forever
I am brand new to this, and I was trying out the pytorch DCGan Tutorial here: DCGAN Tutorial — PyTorch Tutorials 1.12.1+cu102 documentation. Based upon the task manager, it seemed to be cpu bound and hardly use any GPU at all. So I wanted to see what NVidia’s profiler says. It normally takes 5-10 minutes to run this tutorial, which I launch the python application from the terminal. So to profile it, I launched:
& “C:\Program Files\NVIDIA Corporation\Nsight Compute 2019.5.0\nv-nsight-cu-cli.bat” -o profile C:/ProgramData/Anaconda3/python.exe d:/DCGAN/tutorial.py
The program appears to run as normal, but when it gets to the training portion, it slows to a crawl, never getting beyond the first hundred images, and the compute exe taking almost an entire core of cpu. Is this expected behavior? I would have thought that the profiler would add 1-10% overhead, not essentially freeze the application.
Also,
& “C:\Program Files\NVIDIA Corporation\Nsight Compute 2019.5.0\nv-nsight-cu-cli.bat” --version
NVIDIA (R) Nsight Compute Command Line Profiler
Copyright (c) 2012-2019 NVIDIA Corporation
Version 2019.5.0 (Build 27346997)
I installed CUDA Toolkit 10.2 for the compute program, but pytorch is using 10.1. Could this cause the issue?
Thanks,
Eric
Nsight Compute collects HW and SW performance metrics for CUDA kernels. Depending on which metrics are selected, kernels may need to be replayed multiple times since not all metrics can be collected in a single pass. This requires that the tool save and restore state such as allocated memory for deterministic results, or limit the GPU clock frequency for stable measurements.
You tool you might be looking for is NVIDIA Nsight Systems | NVIDIA Developer which collects a trace of all CPU and GPU activities with low overhead to give you a realistic timeline view of the application. If from that tool you determine that certain CUDA kernels need optimization, you can selectively profile them with Nsight Compute for further performance analysis.
Thanks! I can’t seem to find the CLI for Nsight Systems for Windows devices, does one exist? Am I correct in thinking that Nsight Systems needs to start the program itself? From the GUI it seems like you can’t start profiling in the middle of an application, you have to have the Gui start the program itself.
There is no command line interface for Windows, yet. You can check the “Features” table on NVIDIA Nsight Systems | NVIDIA Developer to see the exact differences between the platforms.
Yes, you need to launch the program from within Nsight Systems (similar to how you previously started it from within Nsight Compute). Nsight Systems allows you to start without profiling and enable that at a later point, if you want to skip some initial part of the execution, but it needs to be launched from within the tool in any case.
Okay, so I managed to sort of profile my application. The problem is that there was no GPU samples! So I printed out print("device: " + (“cuda” if torch.cuda.is_available() else “cpu”) + “\n”)
and found that my program was running using the cpu when under nsight systems, and cuda when not. My guess was that pytorch was using cuda 10.1 and nsight was using cuda 10.2. So I installed the older version of nsight, and now my program uses CUDA while under nsight. However, I get the following warnings in the diagnostics summary:
Injection	DESKTOP-41SHKD0 (:1:0:1964)	00:01.431
Unsupported CUDA driver version: 10020.
Warning Injection DESKTOP-41SHKD0 (:1:0:1964) 00:01.431
CUDA injection initialization failed.
Warning Analysis DESKTOP-41SHKD0 (:1:0:1964) 00:47.179
CUDA profiling might have not been started correctly.
Zero CUDA events were collected. Does the application use CUDA?
And again no GPU traces. I uninstalled all CUDA 10.2 apis, so my current thinking is that I need to uninstall the graphics driver 441.22 and install an older one:
C:\Users\kulcy>C:\Windows\System32\nvidia-smi.exe
Sun Mar 29 18:59:04 2020
| NVIDIA-SMI 441.22 Driver Version: 441.22 CUDA Version: 10.2 |
However, I see this question: Different CUDA versions shown by nvcc and NVIDIA-smi - Stack Overflow Seems to indicate that it should be fine to have CUDA runtime and driver differences. What should I do here?
Which version of Nsight Systems are you using? The CLI’s nsys --version switch will provide the version number.
Per the GUI-about, I am using Version: 2018.3.3.31-00ef8f4 Windows-x64.
This is the older version that I installed in an attempt to use 10.1 to match pytorch. I don’t have the new version installed anymore, but it was the latest available on the nvidia webset as of about a week ago.
Nsys does not appear to be on the command line, I though NSight systems didn’t have a CLI for Windows?
C:\Users\kulcy>nsys -version
‘nsys’ is not recognized as an internal or external command,
operable program or batch file.
My mistake. I didn’t realize you were operating on Windows. You are correct that the Nsight Systems CLI has not been ported to Windows yet.
It’s not clear why CUDA tracing isn’t working. Based on this document, https://docs.nvidia.com/pdf/CUDA_Compatibility.pdf, it seems like it should work.
Can you collect an injection log that should help us debug your situation? Do the following:
  1. Copy the nvlog.config.template file from the host-windows-x64 directory to the directory where the target application exists.
  2. Rename nvlog.config.template as nvlog.config.
  3. Run a collection. The file nsight-sys.log should be created in the directory that contains the nvlog.config file.
  4. Send me that file.
Here it is: nsight-sys.log (12.7 KB)
Can you install the latest version of Nsight Systems, 2020.2, collect another injection log, and send it to me?
I downloaded nsight systems 2020.1, then I started the trace. While it was processing the output, I checked the log and noticed that it had appended to the old output. So I deleted the log, and clicked stop button, and since then I haven’t been able to get it to collect at all. When I click on start, it gives me a pop up like so: image
When I press refresh or select on the computer, it just hangs. I have tried restarting the computer, and I also tried uninstalling and reinstalling nsight systems. Same issue.
Thanks,
Eric
Hi Eric,
Nsight Systems 2020.1 should indeed support tracing of a CUDA 10.2 application.
My suggestions are below:
#1: Uninstall Nsight Systems, delete the folder it was installed in, and re-install Nsight Systems.
#2: If the above does not work then could you please capture a log of the Nsight Systems host app (this is slightly different from the log you captured a few days ago):
  1. Make a copy of the file nvlog.config.template file from the host-windows-x64 directory in the same host-windows-x64 directory.
  2. Rename nvlog.config - Copy.template as nvlog.config.
  3. Run a collection. The file nsight-sys.log should be created in the host-windows-x64 directory.
BTW, there is a new release out - Nsight System 2020.2. You might want to give it a try.
Doron
Okay, I installed 2020.2 and uninstalled .1 I can now record traces again, but I am back to the issue that the python program doesn’t think there is a GPU. Attached is the log. nsight-sys.log (54.9 KB)
Interestingly the cmd windows that pops up when I run the program no longer shows the program output, instead just a black screen. This feels like a regression from 2020.1. It is clearly doing something though since the cpu is at 100%. Diagnostics summary has the following:
11432 -00:00.173
Process 11432 was launched by the profiler
Information Analysis 00:00.000
Profiling has started.
Information Daemon 11432 00:00.000
Profiler attached to the process.
Information Injection 11432 00:01.259
Common injection library initialized successfully.
Information Injection 11432 00:01.304
CUDA injection initialized successfully.
Information Injection 11432 00:39.996
Number of CUPTI events produced: 2, CUPTI buffers: 20.
Information Injection 11432 00:39.997
Number of CUPTI events produced: 4, CUPTI buffers: 20.
Information Analysis 00:42.865
Profiling has stopped.
Information Analysis 11432 02:11.557
Number of CUDA events collected: 2.
Warning Analysis 11432 02:11.557
Vulkan profiling might have not been started correctly.
No Vulkan events collected. Does the process use Vulkan?
Nsight Systems 2020.2 (and later) captures the standard output and error streams of the target application. You can see the output to these streams by selecting “Files” from the views drop-list (which shows the Timeline view by default).
