When the CUDA c program is executed on windows 7 , When the program control reaches to global function following error is displayed
Find Source tmpxft_00001588_00000000-2_kernel.cudafe1.stub.c
and in output variable value is displayed as 0 (Zero)
PRogram is correct n gets compiled also.
Kindly reply
“PRogram is correct n gets compiled also.”
compilation does not guarantee execution - the reason why debuggers are needed
although i can not confirm this: stub is generally associated with the kernel configuration - the pre-kernel launch evaluator
i) post your code
also:
a) use the debugger and step your program; note the first line of divergence
b) add error checking (cudaGetLastError()) before and after your kernel launch
c) add a breakpoint within your kernel, and see if you can reach that
d) interpret the results of a), b) and c)
