When executing this code:
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
int main()
const int ARRAY_SIZE = 1000000;
const int ARRAY_BYTES = ARRAY_SIZE * sizeof(float);
float h_in[ARRAY_SIZE];
for (size_t i = 0; i < ARRAY_SIZE; i++)
h_in[i] = 0;
float *d_in, *d_out;
cudaMalloc((void **)&d_in, ARRAY_BYTES);
cudaMalloc((void **)&d_out, sizeof(float));
cudaMemcpy(d_in, h_in, ARRAY_BYTES, cudaMemcpyHostToDevice);
return 0;
My program crashes, I can’t seem to get any debugging output.
It’s a simplified bit from a tutorial i’m following where the tutorial code wouldn’t compile, so I narrowed it down to this. (from Udacity, chapter 3 (reduce using global and shared memory)).
It happens in both VS2015 and VS2017 with cuda 9.1 with the latest 3 patches, it happens in the above code only if I take an array size above 966144 bytes and only on occasion.
I’m running this on a i7-6800k with a GTX1080.
