I want to convert an image obtained by gstreamer with a program in c++.
My problem is that when I get the frame by:
gst_pad_add_probe (src_pad, GST_PAD_PROBE_TYPE_BUFFER, frame_processing, NULL, NULL);
I get the gpuMat, this works fine, but when I try to convert to gray with cuda, I receive an aborted (core dumped) and the program crash.
To further complete this issue, my pipeline is:
rtspsrc location=rtsp://192.168.1.162/z3-1.mp4 ! application/x-rtp,encoding-name=H265,payload=96,framerate=25/1 ! queue max-size-time=500 ! rtph265depay ! video/x-h265, stream-format=byte-stream,framerate=25/1 ! nvv4l2decoder enable-max-performance=true ! queue max-size-bytes=0 max-size-time=500 ! nvvidconv output-buffers=5 name=myconv ! video/x-raw(memory:NVMM), format=RGBA ! nvvidconv output-buffers=5 ! video/x-raw(memory:NVMM), format=NV12 ! queue max-size-bytes=0 max-size-time=500 ! nvv4l2vp9enc maxperf-enable=true bitrate=2000000 ! video/x-vp9 ! queue max-size-bytes=0 max-size-time=500 ! rtpvp9pay ! udpsink host=224.0.0.0 port=5000 max-lateness=500 sync=false qos=false auto-multicast=true
And the code that throws the error is:
cv::cuda::cvtColor(d_mat, d_mat,cv::COLOR_RGBA2BGR);
where d_mat is the gpuMat extracted of CUeglFrame.
I don’t understand what is wrong here because with the same code in the jetson TX2 it works fine and in the Xavier it is failing.
Any ideas?
After catching the error and printing it, I see the following error:
OpenCV(4.4.0) /tmp/build_opencv/opencv_contrib/modules/cudev/include/opencv2/cudev/grid/detail/transform.hpp:264: error: (-217:Gpu API call) no kernel image is available for execution on the device in function ‘call’
