I need help understanding an issue I’m encountering with my system. I’m using a Jetson Xavier AGX hardware platform with the following software configurations:
• Hardware Platform (jetson Xavier AGX )
• DeepStream Version 6.3
• JetPack Version 5.1.2 GA
• TensorRT Version 8.5.2.2
I’ve employed a YOLOv8 model to detect faces connected to another YOLOv8 model for person detection. Initially, everything works fine for about an hour. However, after that time, the system stops and shows a warning. Surprisingly, the process doesn’t terminate, as confirmed by the command ‘ps aux | grep python3,’ but it stops receiving frames.
Here’s a snippet of the logs:
Unknown or legacy key specified 'is-classifier' for group [property]
0:00:03.955841848 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary3-nvinference-engine>e[00m NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 5]: deserialized trt engine from :test_model_age/age_googlenet.caffemodel_b2_gpu0_fp32.engine
0:00:04.005038422 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary3-nvinference-engine>e[00m NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 5]: Use deserialized engine model:age_googlenet.caffemodel_b2_gpu0_fp32.engine
0:00:04.014347932 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary3-nvinference-engine>e[00m [UID 5]: Load new model:config_age_1.txt sucessfully
0:00:04.940455311 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary2-nvinference-engine>e[00m NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 4]: deserialized trt engine from :model_classi_gendre/gender_net.caffemodel_b2_gpu0_fp32.engine
0:00:04.989419231 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary2-nvinference-engine>e[00m NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 4]: Use deserialized engine model: model_classi_gendre/gender_net.caffemodel_b2_gpu0_fp32.engine
0:00:04.993044021 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary2-nvinference-engine>e[00m [UID 4]: Load new model:dstest2_sgie2_config.txt sucessfully
0:00:05.899151015 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary1-nvinference-engine>e[00m NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 3]: deserialized trt engine from :gender_googlenet/gender_googlenet.caffemodel_b2_gpu0_fp32.engine
0:00:05.947119996 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary1-nvinference-engine>e[00m NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 3]: Use deserialized engine model: gender_googlenet/gender_googlenet.caffemodel_b2_gpu0_fp32.engine
0:00:05.950555495 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary1-nvinference-engine>e[00m [UID 3]: Load new model:confi_genre_google.txt sucessfully
0:00:06.888169950 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference2>e[00m NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 2]: deserialized trt engine from :model_face_detection/yolov8n-face.onnx_b2_gpu0_fp32.engine
0:00:06.936303037 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference2>e[00m NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 2]: Use deserialized engine model: model_face_detection/yolov8n-face.onnx_b2_gpu0_fp32.engine
0:00:06.942079154 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference2>e[00m [UID 2]: Load new model:config_detect_face.txt sucessfully
0:00:08.201292784 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference1>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :model_b2_gpu0_fp32.engine
0:00:08.248198342 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference1>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: model_b2_gpu0_fp32.engine
0:00:08.252823927 e[331m27756e[00m 0x3ac38b50 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference1>e[00m [UID 1]: Load new model:config_person_2rtsp.txt sucessfully
sh: 1: modprobe: not found
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Warning Message…
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:4575: => VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation
0:07:10.377733093 e[331m27756e[00m 0x3ac431e0 e[33;01mWARN e[00m e[00m nvinfer gstnvinfer.cpp:1463:convert_batch_and_push_to_input_thread:<primary-inference2>e[00m error: NvBufSurfTransform failed with error -3 while converting buffer
0:07:10.385980199 e[331m27756e[00m 0x3ac431e0 e[33;01mWARN e[00m e[00m nvinfer gstnvinfer.cpp:1463:convert_batch_and_push_to_input_thread:<primary-inference2>e[00m error: NvBufSurfTransform failed with error -3 while converting buffer
The warning seems to indicate an issue with image scale factors exceeding 16, which impacts the VIC configuration. This might be causing problems with buffer transformations. I hope someone can assist in resolving this issue.
