Can any one help with installation of the pro-priority drivers in latest proxmox for VGPU (i got a trial license)
I dont find any guide for proxmox, specially vgpu on latest drivers.
I tried installing the latest driver 510.47.03, but its not working.
i did dpkg -i nvidia-linux-grid-510_510.47.03_amd64.deb then removed the blacklist nvidia driver from /etc/modprobe.d/pve-blacklist.conf and rebooted the machine and did nvidia-smi
I am getting NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Hello how are you? I hope so, I’m temporarily with an A5000 board, I made a Tutorial with pieces of code that I found from other tutorials on the internet and I was testing, I have the drivers on the HOST working, but at the moment I don’t know what else to do, if you can help , thank you. see here the tutorial
I tried to install NVIDIA-GRID-Linux-KVM-510.85.03 an dI get the below error
ERROR: Failed to run /usr/sbin/dkms build -m nvidia -v 510.85.03 -k 6.8.4-3-pve: Sign command:
/lib/modules/6.8.4-3-pve/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Building module:
Cleaning build area...
'make' -j32 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=6.8.4-3-pve IGNORE_CC_MISMATCH='' modules......(bad exit
status: 2)
Error! Bad return status for module build on kernel: 6.8.4-3-pve (x86_64)
Consult /var/lib/dkms/nvidia/510.85.03/build/make.log for more information.
