Initially I thought it was my code issue. A search through the forum revealed that there r others who have come across this.
I have got a very simple kernel that reproduces this problem. I am in a CUDA 1.1 environment and I am NOT the “administrator” of my system.
#include <cuda.h>
#include <stdio.h>
struct texture <float> texrefFloat;
void *devptr;
__global__ void mykernel(texture <float> ref, float *g_out)
float data;
data = tex1Dfetch(ref, threadIdx.x);
g_out[threadIdx.x] = data+1;
return;
int output[32];
int main()
dim3 grid, block;
devptr = NULL;
cudaMalloc(&devptr, 100*sizeof(float));
if (devptr == NULL)
printf("cudaMalloc() failed.\n");
return -1;
cudaBindTexture(0, texrefFloat, devptr, 100*sizeof(float));
cudaMemset(devptr, 0, 100*sizeof(float));
block.x = 32;
// mykernel <<< grid, block >>> (texrefFloat, (float *)devptr);
//cudaThreadSynchronize();
// cudaMemcpy(output, devptr, 32*sizeof(float), cudaMemcpyDeviceToHost);
return 0;
I am just learning textures. So, Please excuse me if its the mistake of my program.
When I compile this code, I get the message:
1>------ Build started: Project: texture, Configuration: Debug Win32 ------
1>Performing Custom Build Step
1>tex.cu
1>tex.cudafe1.gpu
1>tex.cudafe2.gpu
1>Internal error
1>nvcc error : ‘ptxas’ died with status 0xC0000005 (ACCESS_VIOLATION)
1>Linking…
1>LINK : fatal error LNK1181: cannot open input file ‘.\Debug\tex.obj’
1>Build log was saved at “file://c:\CUDA\sarnath\texture\Debug\BuildLog.htm”
1>texture - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
