I am seeing a number of warnings of a same type (Stack size for entry function … cannot be statically determined) from ptxas. One of possible reasons could be recursion in code, but the symbols are quite big to read once demangled. Are there any built-in method for figuring out such warnings? Could ptxas provide some more information?
I found cuobjdump. I was thinking maybe dumping PTX / assembly could allow me to look for any recursions.
ptxas warning : Stack size for entry function '_ZN6thrust6system4cuda6detail6detail23launch_closure_by_valueINS2_17for_each_n_detail18for_each_n_closureINS_12zip_iteratorINS_5tupleINS7_INS8_INS_17counting_iteratorIiNS_11use_defaultESA_SA_EENS_17constant_iteratorIPdSA_SA_EENSC_IiSA_SA_EENS_9null_typeESG_SG_SG_SG_SG_SG_EEEENS_20permutation_iteratorINS_6detail15normal_iteratorINS_10device_ptrI10devcomplexIdEEEEENS_18transform_iteratorIN13strided_rangeISQ_E14stride_functorENS9_IlSA_SA_SA_EESA_SA_EEEESG_SG_SG_SG_SG_SG_SG_SG_EEEEjNSK_30device_unary_transform_functorI36SpecialIncoherentResonanceCalculatorEENS3_20blocked_thread_arrayEEEEEvT_' cannot be statically determined
ptxas warning : Stack size for entry function '_ZN6thrust6system4cuda6detail6detail23launch_closure_by_valueINS2_13reduce_detail24unordered_reduce_closureINS_18transform_iteratorI26SpecialResonanceIntegratorNS_12zip_iteratorINS_5tupleINS_17counting_iteratorIiNS_11use_defaultESC_SC_EENS_17constant_iteratorIPdSC_SC_EENS_9null_typeESH_SH_SH_SH_SH_SH_SH_EEEE10devcomplexIdESC_EElSL_NS_6detail15normal_iteratorINS_7pointerISL_NS2_3tagESC_SC_EEEENS_4plusISL_EENS3_20blocked_thread_arrayEEEEEvT_' cannot be statically determined
ptxas warning : Stack size for entry function '_ZN6thrust6system4cuda6detail6detail23launch_closure_by_valueINS2_13reduce_detail24unordered_reduce_closureINS_18transform_iteratorI23SpecialDalitzIntegratorNS_12zip_iteratorINS_5tupleINS_17counting_iteratorIiNS_11use_defaultESC_SC_EENS_17constant_iteratorIPdSC_SC_EENS_9null_typeESH_SH_SH_SH_SH_SH_SH_EEEENSA_IddddddSH_SH_SH_SH_EESC_EElSK_NS_6detail15normal_iteratorINS_7pointerISK_NS2_3tagESC_SC_EEEE17SpecialComplexSumNS3_20blocked_thread_arrayEEEEEvT_' cannot be statically determined
ptxas warning : Stack size for entry function '_ZN6thrust6system4cuda6detail6detail23launch_closure_by_valueINS2_17for_each_n_detail18for_each_n_closureINS_12zip_iteratorINS_5tupleINS7_INS8_INS_17counting_iteratorIiNS_11use_defaultESA_SA_EENS_17constant_iteratorIiSA_SA_EENSC_IPdSA_SA_EENS_9null_typeESG_SG_SG_SG_SG_SG_EEEENS_6detail15normal_iteratorINS_10device_ptrIdEEEESG_SG_SG_SG_SG_SG_SG_SG_EEEEjNSJ_30device_unary_transform_functorI11MetricTakerEENS3_20blocked_thread_arrayEEEEEvT_' cannot be statically determined
