I would like to draw your attention to a putative bug in the current compiler release which produces very subtile effects with my code.The test program is an excerpt from the affected code that can reproduce the following error:
The array ‘efdd’ is iteratively used for calculations an shall be nullified at the beginning of each iteration (iloop).
So the write statement after the call to ‘init’ should give zeroes at any time.
Compiling the code with
pgf90 -O0 test.f -o test
pgf90 -O1 test.f -o test
does so. However
pgf90 -O2 test.f -o test
does not. In this case the values from ‘efdd(j,i)=dble(ij)’ will be displayed.
The observed misbehavior can be suppressed by uncommenting 'write(6,)‘hello’’ right after ‘efdd(is,iv)=0.d0’ or by using the -Kieee switch at compile time.
Since ‘efdd’ is explicitly filled with values each iteration the nullification in ‘init’ must be executed no matter which optimization level is chosen.
Older versions of the compiler are not affected (12.5, 13.2) as well as gfortran.
program test
implicit double precision(a-h,o-z)
common/block1/iloop
common/block2/efdc(35,3),efdd(35,3)
common/block3/f(35,3)
common/block4/nsp(6)
nm=4
nsp(1)=nm
nsp(2)=2*nm
nsp(3)=nm
nsp(4)=nm
efdd=0.0d0
do iloop=1,3
call init
write(6,*)efdd
do i=1,3
do j=1,10
efdd(j,i)=dble(i*j)
end do
end do
! write(6,*)efdd
end do
end program test
subroutine init
common/block1/iloop
write(6,*)'iloop= ',iloop
is=0
do 10 i1=1,3
do 20 i2=1,nsp(i1)
is=is+1
do 30 iv=1,3
efdd(is,iv)=0.d0
! write(6,*)'hello'
if(iloop.eq.1) then
efdc(is,iv)=0.d0
f(is,iv)=0.d0
endif
30 continue
20 continue
10 continue
return
end
This was tested on a system with:
output from pgf90 --version:
I would like to draw your attentaion to a putative bug in pgf90 14.7
pgf90 14.7-0 64-bit target on x86-64 Linux -tp piledriver
The Portland Group - PGI Compilers and Tools
output from uname -srv:
Linux 3.0.101-0.35-default #1 SMP Wed Jul 9 11:43:04 UTC 2014 (c36987d)
MD Opteron™ Processor 6380
Best regards
BWB
