I tried using std::tuple
in my kernel code, but received many error: this declaration may not have extern "C" linkage
errors that pointed to utility
and tuple
It complains on the include. The following repros for me.
from pycuda.compiler import SourceModule
mod = SourceModule("""#include <tuple>""")
Do I need to do something special in my kernel code or in my Python code to specify I want to use the C++ compiler?
Cuda version: 11.8
PyCuda version: 2022.2.1
Hi john.novak1024,
We may need to move your post to another forum since I’m not familiar with Python or pyCUDA. However, I just looked at pyCUDA’s Documentation for SourceModule:
https://documen.tician.de/pycuda/driver.html#pycuda.compiler.SourceModule
Where it says:
Unless no_extern_c is True , the given source code is wrapped in extern “C” { … } to prevent C++ name mangling.
Given “tuple” uses templating, it can be wrapped in an extern “C” block.
Can you try adding “no_extern_c=True” to see if it works around this issue?
-Mat
