pyTorch 2.0.0.nv23.05
I am using 2.0.0.nv23.05 on my Jetson Orin Nano.
I am working on data parallel with pyTorch, but I got this error:
from torch.distributed import init_process_group, destroy_process_group
ImportError: cannot import name ‘init_process_group’ from ‘torch.distributed’
Is the pyTorch for Jetson not the same as the pyTorch?
I can run my program on my Linux Desktop, but got this error when I ran on Jetson.
Hi @hlau2, that PyTorch wheel for Jetson wasn’t built with USE_DISTRIBUTED enabled, so it doesn’t have torch.distributed available. You can either disable the code, or rebuild PyTorch with USE_DISTRIBUTED.
You can find instructions on building PyTorch from source in this topic:
Thanks for your reply.
The build from source provides pyTorch v1.11?
If I want to build with the v2.1.0 wheel for Jetson again, how can I enable the USE_DISTRIBUTED?
Which file should I edit?
And it is interesting that the official documentation does not contain these content, but a post in forum does.
@hlau2 if you build PyTorch 2.1, you don’t need any patches for Jetson and can build it straight away like normal.
To enable torch.distributed in the build, just export USE_DISTRIBUTED=1 and apt-get install libopenblas-dev libopenmpi-dev beforehand.
I cloned the pyTorch v2.1.0, and then installed the packages, and
export USE_NCCL=0
export USE_QNNPACK=0
export USE_PYTORCH_QNNPACK=0
export TORCH_CUDA_ARCH_LIST=“7.2;8.7”
export PYTORCH_BUILD_VERSION=2.1.0
export PYTORCH_BUILD_NUMBER=1
and then python3 setup.py bdist_wheel
it tooks few hours and stuck, because of memory. is it correct?
UPDATE: It actually dead.
g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
[413/1605] Building CUDA object caffe2/CMakeFiles/torch_cuda.dir/__/aten/src/ATen/native/cuda/LogcumsumexpKernel.cu.o
ninja: build stopped: subcommand failed.
Python 3.8.10 (default, May 26 2023, 14:05:08)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
torch.distributed.is_available()
False
import torch.distributed as dist
I built the pyTorch with USE_DISTRIBUTED=1, and I can import the torch.distributed now.
But, it still returns False on torch.distributed.is_available().
Why?
@hlau2 I haven’t used distributed mode, but I would check torch.__config__.show() and the PyTorch source to see what torch.distributed.is_available() is checking for.
