Hi @hlau2, that PyTorch wheel for Jetson wasn’t built with USE_DISTRIBUTED enabled, so it doesn’t have torch.distributed available. You can either disable the code, or rebuild PyTorch with USE_DISTRIBUTED.
You can find instructions on building PyTorch from source in this topic:
