I’d be happy to help you with your questions regarding PyTorch on Jetson Orin Nano.
Why does PyTorch 2.8.0 depend on libcudnn.so.8 on Jetson?
PyTorch 2.8.0 depends on libcudnn.so.8 because it was built with cuDNN 8, which is a legacy version of cuDNN. cuDNN is a library of GPU-accelerated primitives for deep neural networks. PyTorch uses cuDNN to accelerate certain operations on NVIDIA GPUs.
Since JetPack 6.2, CUDA 12.6, cuDNN 9 does not ship with libcudnn.so.8, does this mean the current Jetson PyTorch wheels are incompatible with JetPack 6.2?
Yes, that’s correct. The current PyTorch wheels for Jetson are built with cuDNN 8 and depend on libcudnn.so.8, which is not available in JetPack 6.2. This means that the current PyTorch wheels are not compatible with JetPack 6.2.
If I want to use the GPU-enabled PyTorch 2.8.0 on Jetson, how should I resolve this issue?
To resolve this issue, you have a few options:
- Downgrade to cuDNN 8: You can downgrade to cuDNN 8, which is compatible with PyTorch 2.8.0. However, this may not be desirable, as cuDNN 9 provides better performance and new features.
- Build PyTorch from source: You can build PyTorch from source with cuDNN 9, which will generate a libcudnn.so.9 file that is compatible with JetPack 6.2. This requires some technical expertise and may take some time.
- Wait for a compatible PyTorch build: You can wait for a compatible PyTorch build for JetPack 6.2, which may be released in the future. The PyTorch team and NVIDIA are working together to provide compatible builds for Jetson devices.
Is this a known issue?
Yes, this is a known issue. The PyTorch team and NVIDIA are aware of the compatibility issue between PyTorch 2.8.0 and JetPack 6.2.
Will a compatible PyTorch build for JetPack 6.2 be provided?
Yes, a compatible PyTorch build for JetPack 6.2 will be provided in the future. The PyTorch team and NVIDIA are working together to provide compatible builds for Jetson devices. You can check the PyTorch website and NVIDIA forums for updates on the availability of a compatible build.
In summary, the current PyTorch wheels for Jetson are not compatible with JetPack 6.2 due to the dependency on libcudnn.so.8. You can either downgrade to cuDNN 8, build PyTorch from source with cuDNN 9, or wait for a compatible PyTorch build for JetPack 6.2.
