Hi @6200575, if you run g++
from your terminal, is it found on your system?
Can you run sudo apt-get install build-essential
Hi @hanyanfeng2012, are you trying to install it with pip3
Is this the URL you downloaded the wheel from? https://nvidia.box.com/shared/static/p57jwntv436lfrd78inwl7iml6p13fzh.whl
Is that possible to support a higher version of python here, such as python 3.8 or 3.9?
Yes, you would need to build PyTorch from source. The instructions I used to built it for 3.6 are in the first post of the topic (so substitute pip3.8 for pip3, ect). There are various folks on this topic who have built it for 3.7/3.8, and there was another topic about it here:
I am trying to install the torch-vision but an error is showing up this error -->>
the above error is also shown when trying to import torch,
and the first line of setup.py is also import torch so import torch is a problem and my python version is 3.6.9 .
Hi @ashishad14, does the same thing happen if you just import numpy
If so, try setting export OPENBLAS_CORETYPE=ARMV8
beforehand
(Illegal instruction (core dumped) on import for numpy 1.19.5 on ARM64 · Issue #18131 · numpy/numpy · GitHub )
no numpy is simply getting imported
What is the actual error you are getting? I don’t see it in your post above.
Does it have error if you run this?
python3
>>> import numpy
>>> import torch
[quote=“dusty_nv, post:769, topic:72048”]
OK gotcha, glad that it is working for you now.
If you are building/installing torchvision into a python virtual environment (virtualenv), sudo is not required:
python3 setup.py install
Also, I noticed if you build torchvision into a python virtual environment for the current user ( (py36dl) me@jetsonnano:~/torchvision$ python3 setup.py install --user
), python sometimes cannot locate the torchvision package, especially from a virtualenv or outside the user’s HOME directory. Modifying the PYTHONPATH is a possible workaround.
Hi everyone,
earlier I was facing an issue of importing the pytorch in terminal, that problem got resolved and now I am facing problem on importing the pytorch in jupyter lab.
OSError: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
I ran over the same error. I got following from here which resolved this issue for me: export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
If you open a terminal from within Jupyter, and echo $LD_PRELOAD
, does it show /usr/lib/aarch64-linux-gnu/libgomp.so.1
I think this is due to the compatibility issue that is because of the jetpack version as u have mentioned in this (PyTorch for Jetson)
that the latest version of PyTorch only works with the jetpack 4.5 and not with jetpack 4.5.1 which I currently mounted on my SD card.
Thank you @dusty_nv @dkreutz @kaisar.khatak
I don’t believe so, myself and others run those wheels on JetPack 4.4 / 4.5 / 4.5.1 without issue. The CUDA libraries are basically the same version between those JetPack releases so they can run the same wheel. Also, that intermittent issue with libgomp had appeared as far back as 2019 (not sure why)
Does the problem only occur for you in JupyterLab?
In an ordinary terminal (not in Jupyter), can you run:
$ export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
$ python
>>> import torch
Hi @dusty_nv ,
Is there already a patch available to build LibTorch from source for JP4.5.1?
(Or is there no patching needed anymore?)
best regards,
fabi
Hi @fabian.groh, libtorch should automatically be built when you build the PyTorch wheel.
The patch to the PyTorch source typically depends on the version of PyTorch you are patching and not the version of JetPack. For example, the PyTorch v1.8.0 patch works on JetPack 4.4 - 4.5.1.
