(Q) CUFFT, how to use cufft function.. CUFFT
hello,
I have a question on cufft.
now, I use cufft. It is my first time.
there are some cufft functions in cufft.h. For example, cufftPlan2d, cufftExecC2C…
Can I use them at global??
I can use them at main…I want to use them at global.
thanks.
I don’t think you can do what you are asking about. All those functions are host side functions, intended to be called by the host cpu only.
Thank you for your reply.
is there any method to use them at global??
I want to calculate some processes in gpu without cudaMemcpy.
global_ void fft_Cal(Complex *input_A, Complex input_B…)
ifft~~;
normalization;
A=abs
phase;
fft;
It is a fundamental feature of CUDA that kernels (what you are calling global functions) can’t call other kernels, so no.
it’s impossible to call cufft functions from inside kernels.
But you can split the kernel into a few parts, like
global_ void fft_Cal_1(Complex *input_A, Complex input_B…)
normalization;
A=abs
phase;
and call
fft;
fft_Cal_1;
ifft;
