for years i’ve been using cuFFT to speed-up my signal processing application, and as I always did multiple contiguous 1D FFTs, cufftPlan1D totally fulfilled my needs.
Now I need to do something a bit more tricky. My data are stored in a 3D matrix of size 512x512x16, and I need to perfrom :
512x16 contiguous FFTs of size 512 in the first dimension => I can use cufftPlan1d like I always did for that
tricky part : 512x16x32 non-contiguous (stride 32) FFTs of size 16 along the second dimension but stored in a contiguous way (see below).
In the cuFFT documentation, there’s cufftPlanMany which some of the input parameters are far from being crystal clear for me.
So my questions are :
Can I perform these 2 operations using a single 2D-FFT plan ? (i doubt about it)
At least, can I use cufftPlan1d then cufftPlanMany to do this ? If yes, I suppose I won’t be able to batch all my FFTs accross dimension 2 because the batch would be on dimension 1 and dimension 3. Should I batch on dimension 1 and use streams for the loop on dimension 3 ?
Jeff
