Question about Secondary GIE
• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) Questions
I have some questions about how secondary GIE works. In my project I have a primary GIE that detects people. Then I have another model for mask detection as secondary GIE. In configuration file for secondary GIE model, I have operate on class for “person” class. But I have some questions how this pipeline works:
  1. What is the input for secondary gie? The entire frame with a filter applied for the chosen class (“person”) or the cropped image (the bounding box) of detected people?
  2. Can I choose if i want secondary gie to detect on the entire frame or the person’s bounding box? If so, what is the configuration field for that?
  3. Is pyds.NvDsFrameMeta.source_frame_height the frame height that is the height of the frame given as input for the object detection model?
Thank you!
Cropped ROI
check process-mode and operate-on-class-ids , refer Gst-nvinfer — DeepStream documentation
No, generally, it’s the frame width/height set in nvstreammux
