I have a question about declaring an array as shared. I though that the following code should output the same (i.e. all zeros), whether the array hd is defined as shared or as a simple float, but the code with the array declared as shared outputs 0, 1, 2, 3, … Why is this happening? I thought that even when declared as shared, the arrays were still private to each thread. Is this true?
__global__ void test(int n)
//__shared__ float hd[12];
float hd[12];
int t = threadIdx.x;
int k;
for ( k=0; k<12; k++ ) *(hd+k) = 0;
if (t==0) {
for (k=0; k<12; k++ ) printf("%.10f\n",*(hd+k));
for (k=0;k<12;k++) *(hd+k) = k;
