If my question is off topic or already asked i’m sorry. I’ve read article about it but still it’s not clear in my mind. Thanks for your help in advance.
//counter = 0
__global__ kernel(volatile int* buffer, int *counter)
int tid = threadIdx.x + blockIdx.x * blockDim.x;
if(/* condition */)
buffer[atomicAdd(counter,1)] = tid;
__threadfence();
else
/* Some computation */
/* [HERE], Can I be sure that can every threads in every blocks read same value from buffer array ? */
I’ve this sort of kernel which has massive hierarchy (<<<512,1024>>>. Some of it’s threads write data into buffer array in order. I’m keeping my counter into global memory and increasing it using atomics.
My question is that at the last line, Can I be ensure that can every threads in every blocks read same value from buffer array ? Because does threadfence guarantees that?
i would think that threadfence implies a memory barrier, that in turn helps to preserve memory transaction ordering
i would also think that the above expects or implies across-block synchronization
i do not see how threadfence can be used to ensure across-block synchronization
ask njuffa to code an across-block memory barrier/ synchronization primitive for you
@little_jimmy thanks for answer. I was thinking more or less same with you. But In this case, it didn’t help at all :) I also tried to move __threadfence method call from line-8 to line-14. nothing changed. Am I confused semantic of threadfence ?
If you want to guarantee that a thread sees a value written by another thread in another threadblock, you will need some kind of grid-wide synchronization (execution) barrier.
the simplest canonical grid-wide execution barrier is the kernel launch
other grid-wide constructed execution barriers generally require considerable care in correct use to avoid deadlock.
The GPU memory model is a bit tricky and txbob has the main idea correct here, but it is important to remember that none of the thread fences affect the GPU caches. If you really want to preserve memory ordering across threads on different SMs, make sure to use memory instructions that bypass (or write through as needed) the L1 caches.
" (subject to the caching restrictions described in the doc link I provided)."
to wit:
“Note that for this ordering guarantee to be true, the observing threads must truly observe global memory and not cached versions of it; this is ensured by using the volatile keyword…”
You may want to read section 5 of that VT paper you linked. In-kernel grid-wide synchronization schemes frequently depend on all threads being schedulable (the threadblock-draining approach being a notable exception). Without going into a careful description of what this means or would require, a fairly simple way to satisfy it would be to launch at most 1 threadblock per SM, which is exactly what is specified as a requirement in section 5 of that paper. In particular:
“Our solution to this problem is to have an one-to-one mapping between thread blocks and SMs. In other words, for a GPU with ‘Y’ SMs, we ensure that at most ‘Y’ blocks are used in the kernel.”
If you are attempting such a scheme with a kernel launch such as you have described:
that cannot possibly be reliable, as you have violated the requirement. There are no GPUs currently that have 512 SMs.
you can be sure that they don’t. maxwell SM can run up to 2048 threads simultaneously, titanx has 24 SMs. so some of your threads need to finish in order to allow other threads to start execution. you need to split it into two kernels
they also can run multiple threads per core, with a tehcnology like HyperThreading on CPUs. So, each SMX/SMM can run up to 2048 threads simultaneously, and entire GPU runs <50k threads. since your job has 512k threads, they can’t run all simultaneously.
from the manual:
At its core are three key abstractions - a hierarchy of thread groups, shared memories, and barrier synchronization - that are simply exposed to the programmer as a minimal set of language extensions.
These abstractions provide fine-grained data parallelism and thread parallelism, nested within coarse-grained data parallelism and task parallelism. They guide the programmer to partition the problem into coarse sub-problems that can be solved independently in parallel by blocks of threads, and each sub-problem into finer pieces that can be solved cooperatively in parallel by all threads within the block.
This decomposition preserves language expressivity by allowing threads to cooperate when solving each sub-problem, and at the same time enables automatic scalability. Indeed, each block of threads can be scheduled on any of the available multiprocessors within a GPU, in any order, concurrently or sequentially, so that a compiled CUDA program can execute on any number of multiprocessors as illustrated by Figure 5, and only the runtime system needs to know the physical multiprocessor count.
This scalable programming model allows the GPU architecture to span a wide market range by simply scaling the number of multiprocessors and memory partitions
Thread blocks are required to execute independently: It must be possible to execute them in any order, in parallel or in series. This independence requirement allows thread blocks to be scheduled in any order across any number of cores as illustrated by Figure 1 4, enabling programmers to write code that scales with the number of cores.
Threads within a block can cooperate by sharing data through some shared memory and by synchronizing their execution to coordinate memory accesses.
