Question: time counting with/without memcpy
Hi all,
I’m not sure if anyone else discussed this question before, if did, sorry for the reposting.
The problem is, when I tried to count the time of the matrixMul from CUDA SDK examples, I moved the statement of copying device memory back to the host after the line of CUT_SAFE_CALL(cutStopTimer(timer)). Then I got two different time results (I use 512 by 512 for all matrices to make them bigger):
$ ./debug/matrixMul
Processing time: 3.235000 (ms)
$ ./release/matrixMul
Processing time: 0.031000 (ms)
Why in release mode, it runs so fast??
But if I don’t change anything except for the size, the results are quite the same.
$ ./debug/matrixMul
Processing time: 5.632000 (ms)
Processing time: 5.035000 (ms)
I’m using nvcc 1.1 and SDK 1.1 btw.
first of all, why are you still using 1.1? 2.0 is pretty cool, we promise :(
the answer, if I’m understanding what you did correctly, is that you don’t have a cudaThreadSynchronize() before you call cutStopTimer. kernel launches are asynchronous, so you’re measuring just the launch, not the kernel’s execution time itself. cudaMemcpy forces a sync before it copies back and blocks until the memcpy is completed, so that should explain the differences.
OH, OK, that makes sense. Thanks! Yep, I’d try 2.0.
