I have a new issu.
I have tranformed TX1 r24.2.3 code to TX2 r28.2.1 … in few second … --’
So , i used same MMAP V4L2 , and moved NvVideoConverter to NvBufferTransform.
All work nice, i can make RGB32 for use NVOSD functions , after a NV12 and a recording in h264.
in_buffer was delete in ach new V4L2 buffer :
But, i check for a memory leak : in 4K ,that’ lost 5Mo / s.
- disable Recording => Leak
- disable NvBufferTransform => Leak
- disable Decoderjpeg function => No Leak
- disable decodeToFd : comment “m_JpegDec->decodeToFd” line and return 1 in Decoderjpeg => No leak
Only V4L2 capture ioctl(_ctx->cam_fd, VIDIOC_DQBUF, &_ctx->cam_buf) => No leak
int MyEncoder::Decoderjpeg( Context_T *_ctx , uint64_t _length )
int fd = -1 ;
bool lret = true;
int jret = -1;
uint8_t *in_buffer ;
if( 0 < _length ) {
if(_ctx->in_buffer != nullptr) {
free(_ctx->in_buffer);
_ctx->in_buffer= nullptr;
_ctx->in_buffer = (unsigned char *)malloc(( _length+1)*sizeof(unsigned char) );
memset(_ctx->in_buffer ,'
int fd = -1 ;
bool lret = true;
int jret = -1;
if( 0 < _length ) {
memset(_ctx->in_buffer ,'\0',( _length+1)*sizeof(unsigned char));
memcpy(_ctx->in_buffer , _ctx->buffers[_ctx->cam_buf.index].cam_start,_length*sizeof(unsigned char));
_ctx->in_file_size = _length;
jret = _ctx->m_JpegDec->decodeToFd(fd, _ctx->in_buffer, _ctx->in_file_size, pixfmt, width, height);
else{
LOG_WARN(" CAMERA [%li] : NvBufferMemMap is NULL ",_ctx->m_Id_Camera );
return fd;
else{
return fd;
here, function to prepare mmap buffer :
bool MyEncoder::PrepareBufferParse(Context_T * _ctx ) {
bool lret = true;
/* Buffer allocation
* Buffer can be allocated either from capture driver or
* user pointer can be used
/* Request for MAX_BUFFER input buffers. As far as Physically contiguous
* memory is available, driver can allocate as many buffers as
* possible. If memory is not available, it returns number of
* buffers it has allocated in count member of reqbuf.
* HERE count = number of buffer to be allocated.
* type = type of device for which buffers are to be allocated.
* memory = type of the buffers requested i.e. driver allocated or
* user pointer */
memset(&_ctx->cam_req, 0, sizeof (_ctx->cam_req));
_ctx->cam_type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
_ctx->cam_req.count = TEST_BUFFER_NUM;
_ctx->cam_req.type = _ctx->cam_type;
_ctx->cam_req.memory = V4L2_MEMORY_MMAP;
if (ioctl(_ctx->cam_fd, VIDIOC_REQBUFS, &_ctx->cam_req) < 0) {
LOG_ERROR("CAPTURE: VIDIOC_REQBUFS");
LOG_ERROR("Failed to request v4l2 buffers: %s (%d)", strerror(errno), errno);
lret = false;
/* Mmap the buffers
* To access driver allocated buffer in application space, they have
* to be mmapped in the application space using mmap system call */
for (uint32_t i = DISABLE; i < _ctx->cam_req.count; i++) {
if( lret ) {
memset(&_ctx->cam_buf,DISABLE, sizeof(_ctx->cam_buf));
_ctx->cam_buf.type = _ctx->cam_type;
_ctx->cam_buf.index = i;
_ctx->cam_buf.memory = V4L2_MEMORY_MMAP;
int err_chk;
if((err_chk=ioctl(_ctx->cam_fd, VIDIOC_QUERYBUF, &_ctx->cam_buf)) < 0) {
LOG_ERROR("CAPTURE: VIDIOC_QUERYBUF");
lret = false;
else {
LOG_INFO("CAPTURE: Prepare MMAP buffer");
_ctx->buffers[i].cam_offset = (size_t) _ctx->cam_buf.m.offset;
_ctx->buffers[i].cam_length = _ctx->cam_buf.length;
_ctx->buffers[i].cam_start = (unsigned char *)mmap(NULL, _ctx->cam_buf.length,
PROT_READ | PROT_WRITE, MAP_SHARED, _ctx->cam_fd,
_ctx->buffers[i].cam_offset);
if (_ctx->buffers[i].cam_start == MAP_FAILED) {
LOG_ERROR("Cannot mmap = %d buffer\n", i);
lret = false;
else {
/* Enqueue buffers
* Before starting streaming, all the buffers needs to be
* en-queued in the driver incoming queue. These buffers will
* be used by thedrive for storing captured frames. */
if(ioctl(_ctx->cam_fd, VIDIOC_QBUF, &_ctx->cam_buf) < 0) {
LOG_ERROR("CAPTURE: VIDIOC_QBUF :" );
LOG_ERROR("- Failed to request v4l2 buffers: %s (%d)",strerror(errno), errno);
lret = false;
return lret;
thats’ work on TX1 …
thanks for help
