Race condition? How to define thread-specific kind of variables?
I am trying to re-write some shared-memory CPU code with CUDA, and I got some problems in finding a thread-specific substitute. In other words, I want each CUDA thread to work with some local variables, without interfering with each other.
A toy code I wrote is pasted below, and I got “Bad” results because of race conditions. I do not need the atomic-add, but that works fine. So the question is, how to make sure no other thread wants the same index of the var array?
__global__ void thread_local_var_test_kernal1(int** worker_array, int* var, int size)
	const int
		blockId = blockIdx.y * gridDim.x + blockIdx.x,
		idx = blockId * blockDim.x + threadIdx.x;
	if (idx < size)
		int* worker = worker_array[threadIdx.x];		// <------- I want worker array to work without race-condition
		var[threadIdx.x]++;		// race condition
		//atomicAdd(&var[threadIdx.x], 1);	// OK
static void thread_local_var_test_kernal_test1(int size)
	int threadsPerBlock = block_dim;
	int blocksPerGrid = (size + threadsPerBlock - 1) / threadsPerBlock;
	int* dev_var = 0;
	cudaMalloc(&dev_var, threadsPerBlock * sizeof(int));
	cudaMemset(dev_var, 0, threadsPerBlock * sizeof(int));
	int** dev_worker_array = 0;
	cudaMalloc(&dev_worker_array, threadsPerBlock * sizeof(int*));
	thread_local_var_test_kernal1 <<<blocksPerGrid, threadsPerBlock>>>(dev_worker_array, dev_var, size);
	cudaDeviceSynchronize();
	printf("================================ CUDA kernal is completed ================================\n");
	int* host_var = (int*)malloc(threadsPerBlock * sizeof(int));
	cudaMemcpy(host_var, dev_var, threadsPerBlock * sizeof(int), cudaMemcpyDeviceToHost);
	cudaFree(dev_var);
	int sum_var = 0;
	for (int i = 0; i < threadsPerBlock; i++)
		printf("%d, ", host_var[i]);
		sum_var += host_var[i];
	printf("CUDA sum = %d (%d is expected).\n", sum_var, size);
	(sum_var == size) ? printf("Good.\n") : printf("Bad.\n");
	free(host_var);
atomics should work.
If you have an orderly pattern (such as your toy code) you can use a classical parallel reduction:
[url]https://developer.download.nvidia.com/assets/cuda/files/reduction.pdf[/url]
Thanks Robert. However, I do not need the sum_var, but I use it just to show “Bad” results. I just updated the code with comments, and what I really need is the worker array to work appropriately without being interfered by other threads. For example, I can pre-allocate the worker arrays in host or another kernal, and use them in the core kernal later.
The way it should work is that, once an array is allocated for each thread, then each thread should be able to re-use the memory for multiple times without the needs of allocate & free.
