Hello all, My first post!
First a quick run down of what im doing:
Im creating a real time path tracer, im currently using a large portion of the smallPT code by Kevin Beason(2008).
Im also using Open GL for the graphics API and OpenCL(obviously) for the computing performance.
Ive ported the code from linux compatible to windows and got it running inside an OpenGL window, it runs at 3fps! but thats only if i set the window size to 40 x 30.
Ok my problem is im trying to figure out how I would go about taking a radiance function that works in Host code and convert it to solely run on the gpu.
My reasons for this is the demanding billion or so calls required from the radiance function(depending on screen size and sample count).
Any input is much appreciated,
Many thanks
Rob
Radiance Code (Kevin Beason, 2008):
Note: ‘Vec’,‘Ray’ and ‘Sphere’ are variable types defined in this program. Xi holds the seed for a random generator.
Vec radiance(const Ray &r, int depth, unsigned short *Xi)
double t; // distance to intersection
int id=0; // id of intersected object
if (!intersect(r, t, id)) return Vec(255,255,255); // if miss, return black
const Sphere &obj = spheres[id]; // the hit object
Vec x=r.o+r.d*t, n=(x-obj.p).norm(), nl=n.dot(r.d)<0?n:n*-1, f=obj.c;
double p = f.x>f.y && f.x>f.z ? f.x : f.y>f.z ? f.y : f.z; // max refl
if (++depth>5) if (erand48(Xi)<p) f=f*(1/p); else return obj.e; //R.R.
if (obj.refl == DIFF)// Ideal DIFFUSE reflection
double r1=2*M_PI*erand48(Xi), r2=erand48(Xi), r2s=sqrt(r2);
Vec w=nl, u=((fabs(w.x)>.1?Vec(0,1):Vec(1))%w).norm(), v=w%u;
Vec d = (u*cos(r1)*r2s + v*sin(r1)*r2s + w*sqrt(1-r2)).norm();
return obj.e + f.mult(radiance(Ray(x,d),depth,Xi));
else if (obj.refl == SPEC) // Ideal SPECULAR reflection
return obj.e + f.mult(radiance(Ray(x,r.d-n*2*n.dot(r.d)),depth,Xi));
Ray reflRay(x, r.d-n*2*n.dot(r.d)); // Ideal dielectric REFRACTION
bool into = n.dot(nl)>0; // Ray from outside going in?
double nc=1, nt=1.5, nnt=into?nc/nt:nt/nc, ddn=r.d.dot(nl);
double cos2t=1-nnt*nnt*(1-ddn*ddn);
if (cos2t<0) // Total internal reflection
return obj.e + f.mult(radiance(reflRay,depth,Xi));
Vec tdir = (r.d*nnt - n*((into?1:-1)*(ddn*nnt+sqrt(cos2t)))).norm();
double a=nt-nc, b=nt+nc, R0=a*a/(b*b), c = 1-(into?-ddn:tdir.dot(n));
double Re=R0+(1-R0)*c*c*c*c*c,Tr=1-Re,P=.25+.5*Re,RP=Re/P,TP=Tr/(1-P);
return obj.e + f.mult(depth>2 ? (erand48(Xi)<P ? // Russian roulette
radiance(reflRay,depth,Xi)*RP:radiance(Ray(x,tdir),depth,Xi)
*TP) :
radiance(reflRay,depth,Xi)*Re+radiance(Ray(x,tdir),depth,Xi)
*Tr);
