Dear @Morganh
I am trying to train on person re-identification model on my custom dataset on 2080TI GPU machine and my dataset size is around 2.4M. but I am getting below issue. (Training got stop automatically after 1 epoch)
Below is the configuration and training logs.
Logs:
Train model
2024-08-20 18:18:36,260 [TAO Toolkit] [INFO] root 160: Registry: ['nvcr.io']
2024-08-20 18:18:36,364 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-pyt
2024-08-20 18:18:36,506 [TAO Toolkit] [WARNING] nvidia_tao_cli.components.docker_handler.docker_handler 267:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/smarg/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
2024-08-20 18:18:36,506 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 275: Printing tty value True
sys:1: UserWarning:
'experiment_market1501_resnet.yaml' is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
<frozen core.hydra.hydra_runner>:107: UserWarning:
/usr/local/lib/python3.8/dist-packages/hydra/_internal/hydra.py:119: UserWarning: Future Hydra versions will no longer change working directory at job runtime by default.
See https://hydra.cc/docs/next/upgrades/1.1_to_1.2/changes_to_job_working_dir/ for more information.
ret = run_job(
Train results will be saved at: /results/market1501/train
Loading pretrained ImageNet model......
│ Subset │ # IDs │ # Images │ # Cameras │
│ Train │ 70493 │ 2232198 │ 10 │
│ Query │ 8416 │ 19865 │ 2 │
│ Gallery │ 23146 │ 76627 │ 2 │
/usr/local/lib/python3.8/dist-packages/pytorch_lightning/trainer/connectors/accelerator_connector.py:441: LightningDeprecationWarning: Setting `Trainer(gpus=[0])` is deprecated in v1.7 and will be removed in v2.0. Please use `Trainer(accelerator='gpu', devices=[0])` instead.
rank_zero_deprecation(
GPU available: True (cuda), used: True
TPU available: False, using: 0 TPU cores
IPU available: False, using: 0 IPUs
HPU available: False, using: 0 HPUs
Missing logger folder: /results/market1501/train/lightning_logs
/usr/local/lib/python3.8/dist-packages/pytorch_lightning/callbacks/model_checkpoint.py:604: UserWarning: Checkpoint directory /results/market1501/train exists and is not empty.
rank_zero_warn(f"Checkpoint directory {dirpath} exists and is not empty.")
LOCAL_RANK: 0 - CUDA_VISIBLE_DEVICES: [0]
/usr/local/lib/python3.8/dist-packages/torch/optim/lr_scheduler.py:138: UserWarning: Detected call of `lr_scheduler.step()` before `optimizer.step()`. In PyTorch 1.1.0 and later, you should call them in the opposite order: `optimizer.step()` before `lr_scheduler.step()`. Failure to do this will result in PyTorch skipping the first value of the learning rate schedule. See more details at https://pytorch.org/docs/stable/optim.html#how-to-adjust-learning-rate
warnings.warn("Detected call of `lr_scheduler.step()` before `optimizer.step()`. "
| Name | Type | Params
0 | model | Baseline | 42.1 M
1 | train_accuracy | Accuracy | 0
2 | val_accuracy | Accuracy | 0
42.1 M Trainable params
256 Non-trainable params
42.1 M Total params
168.317 Total estimated model params size (MB)
/usr/local/lib/python3.8/dist-packages/pytorch_lightning/trainer/connectors/data_connector.py:224: PossibleUserWarning: The dataloader, train_dataloader, does not have many workers which may be a bottleneck. Consider increasing the value of the `num_workers` argument` (try 12 which is the number of cpus on this machine) in the `DataLoader` init to improve performance.
rank_zero_warn(
/usr/local/lib/python3.8/dist-packages/pytorch_lightning/trainer/connectors/data_connector.py:224: PossibleUserWarning: The dataloader, val_dataloader 0, does not have many workers which may be a bottleneck. Consider increasing the value of the `num_workers` argument` (try 12 which is the number of cpus on this machine) in the `DataLoader` init to improve performance.
rank_zero_warn(
Training: 0it [00:00, ?it/s]Starting Training Loop.
Epoch 0: 0%| | 0/33901 [00:00<?, ?it/s]
Epoch 0: 98%|█████▊| 33147/33901 [2:02:53<02:47, 4.50it/s, loss=1.51, v_num=0]
Validation: 0it [00:00, ?it/s]
Validation: 0%| | 0/754 [00:00<?, ?it/s]
Validation DataLoader 0: 0%| | 0/754 [00:00<?, ?it/s]
Epoch 0: 98%|█████▊| 33148/33901 [2:02:54<02:47, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33149/33901 [2:02:54<02:47, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33150/33901 [2:02:54<02:47, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33151/33901 [2:02:54<02:46, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33152/33901 [2:02:55<02:46, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33153/33901 [2:02:55<02:46, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33154/33901 [2:02:55<02:46, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33155/33901 [2:02:55<02:45, 4.50it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33156/33901 [2:02:56<02:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33157/33901 [2:02:56<02:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33158/33901 [2:02:56<02:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33159/33901 [2:02:56<02:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33160/33901 [2:02:57<02:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33161/33901 [2:02:57<02:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33162/33901 [2:02:57<02:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33163/33901 [2:02:57<02:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33164/33901 [2:02:58<02:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33165/33901 [2:02:58<02:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33166/33901 [2:02:58<02:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33167/33901 [2:02:59<02:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33168/33901 [2:02:59<02:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33169/33901 [2:02:59<02:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33170/33901 [2:02:59<02:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33171/33901 [2:03:00<02:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33172/33901 [2:03:00<02:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33173/33901 [2:03:00<02:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33174/33901 [2:03:00<02:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33175/33901 [2:03:01<02:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33176/33901 [2:03:01<02:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33177/33901 [2:03:01<02:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33178/33901 [2:03:01<02:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33179/33901 [2:03:02<02:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33180/33901 [2:03:02<02:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33181/33901 [2:03:02<02:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33182/33901 [2:03:02<02:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33183/33901 [2:03:03<02:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33184/33901 [2:03:03<02:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33185/33901 [2:03:03<02:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33186/33901 [2:03:03<02:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33187/33901 [2:03:04<02:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33188/33901 [2:03:04<02:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33189/33901 [2:03:04<02:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33190/33901 [2:03:04<02:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33191/33901 [2:03:05<02:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33192/33901 [2:03:05<02:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33193/33901 [2:03:05<02:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▊| 33194/33901 [2:03:05<02:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33195/33901 [2:03:06<02:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33196/33901 [2:03:06<02:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33197/33901 [2:03:06<02:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33198/33901 [2:03:06<02:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33199/33901 [2:03:07<02:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33200/33901 [2:03:07<02:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33201/33901 [2:03:07<02:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33202/33901 [2:03:07<02:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33203/33901 [2:03:08<02:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33204/33901 [2:03:08<02:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33205/33901 [2:03:08<02:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33206/33901 [2:03:08<02:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33207/33901 [2:03:09<02:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33208/33901 [2:03:09<02:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33209/33901 [2:03:09<02:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33210/33901 [2:03:10<02:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33211/33901 [2:03:10<02:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33212/33901 [2:03:10<02:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33213/33901 [2:03:10<02:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33214/33901 [2:03:11<02:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33215/33901 [2:03:11<02:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33216/33901 [2:03:11<02:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33217/33901 [2:03:11<02:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33218/33901 [2:03:12<02:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33219/33901 [2:03:12<02:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33220/33901 [2:03:12<02:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33221/33901 [2:03:12<02:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33222/33901 [2:03:13<02:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33223/33901 [2:03:13<02:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33224/33901 [2:03:13<02:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33225/33901 [2:03:13<02:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33226/33901 [2:03:14<02:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33227/33901 [2:03:14<02:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33228/33901 [2:03:14<02:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33229/33901 [2:03:14<02:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33230/33901 [2:03:15<02:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33231/33901 [2:03:15<02:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33232/33901 [2:03:15<02:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33233/33901 [2:03:15<02:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33234/33901 [2:03:16<02:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33235/33901 [2:03:16<02:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33236/33901 [2:03:16<02:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33237/33901 [2:03:16<02:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33238/33901 [2:03:17<02:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33239/33901 [2:03:17<02:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33240/33901 [2:03:17<02:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33241/33901 [2:03:17<02:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33242/33901 [2:03:18<02:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33243/33901 [2:03:18<02:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33244/33901 [2:03:18<02:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33245/33901 [2:03:18<02:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33246/33901 [2:03:19<02:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33247/33901 [2:03:19<02:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33248/33901 [2:03:19<02:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33249/33901 [2:03:19<02:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33250/33901 [2:03:20<02:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33251/33901 [2:03:20<02:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33252/33901 [2:03:20<02:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33253/33901 [2:03:21<02:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33254/33901 [2:03:21<02:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33255/33901 [2:03:21<02:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33256/33901 [2:03:21<02:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33257/33901 [2:03:22<02:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33258/33901 [2:03:22<02:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33259/33901 [2:03:22<02:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33260/33901 [2:03:22<02:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33261/33901 [2:03:23<02:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33262/33901 [2:03:23<02:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33263/33901 [2:03:23<02:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33264/33901 [2:03:23<02:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33265/33901 [2:03:24<02:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33266/33901 [2:03:24<02:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33267/33901 [2:03:24<02:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33268/33901 [2:03:24<02:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33269/33901 [2:03:25<02:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33270/33901 [2:03:25<02:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33271/33901 [2:03:25<02:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33272/33901 [2:03:25<02:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33273/33901 [2:03:26<02:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33274/33901 [2:03:26<02:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33275/33901 [2:03:26<02:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33276/33901 [2:03:26<02:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33277/33901 [2:03:27<02:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33278/33901 [2:03:27<02:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33279/33901 [2:03:27<02:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33280/33901 [2:03:27<02:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33281/33901 [2:03:28<02:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33282/33901 [2:03:28<02:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33283/33901 [2:03:28<02:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33284/33901 [2:03:29<02:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33285/33901 [2:03:29<02:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33286/33901 [2:03:29<02:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33287/33901 [2:03:29<02:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33288/33901 [2:03:30<02:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33289/33901 [2:03:30<02:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33290/33901 [2:03:30<02:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33291/33901 [2:03:30<02:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33292/33901 [2:03:31<02:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33293/33901 [2:03:31<02:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33294/33901 [2:03:31<02:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33295/33901 [2:03:32<02:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33296/33901 [2:03:32<02:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33297/33901 [2:03:32<02:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33298/33901 [2:03:32<02:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33299/33901 [2:03:33<02:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33300/33901 [2:03:33<02:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33301/33901 [2:03:33<02:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33302/33901 [2:03:33<02:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33303/33901 [2:03:34<02:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33304/33901 [2:03:34<02:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33305/33901 [2:03:34<02:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33306/33901 [2:03:35<02:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33307/33901 [2:03:35<02:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33308/33901 [2:03:35<02:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33309/33901 [2:03:35<02:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33310/33901 [2:03:36<02:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33311/33901 [2:03:36<02:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33312/33901 [2:03:36<02:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33313/33901 [2:03:37<02:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33314/33901 [2:03:37<02:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33315/33901 [2:03:37<02:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33316/33901 [2:03:37<02:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33317/33901 [2:03:38<02:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33318/33901 [2:03:38<02:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33319/33901 [2:03:38<02:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33320/33901 [2:03:38<02:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33321/33901 [2:03:39<02:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33322/33901 [2:03:39<02:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33323/33901 [2:03:39<02:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33324/33901 [2:03:40<02:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33325/33901 [2:03:40<02:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33326/33901 [2:03:40<02:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33327/33901 [2:03:40<02:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33328/33901 [2:03:41<02:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33329/33901 [2:03:41<02:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33330/33901 [2:03:41<02:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33331/33901 [2:03:41<02:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33332/33901 [2:03:42<02:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33333/33901 [2:03:42<02:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33334/33901 [2:03:42<02:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33335/33901 [2:03:42<02:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33336/33901 [2:03:43<02:05, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33337/33901 [2:03:43<02:05, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33338/33901 [2:03:43<02:05, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33339/33901 [2:03:43<02:05, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33340/33901 [2:03:44<02:04, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33341/33901 [2:03:44<02:04, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33342/33901 [2:03:44<02:04, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33343/33901 [2:03:45<02:04, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33344/33901 [2:03:45<02:04, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33345/33901 [2:03:45<02:03, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33346/33901 [2:03:45<02:03, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33347/33901 [2:03:46<02:03, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33348/33901 [2:03:46<02:03, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33349/33901 [2:03:46<02:02, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33350/33901 [2:03:46<02:02, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33351/33901 [2:03:47<02:02, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33352/33901 [2:03:47<02:02, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33353/33901 [2:03:47<02:02, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33354/33901 [2:03:48<02:01, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33355/33901 [2:03:48<02:01, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33356/33901 [2:03:48<02:01, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33357/33901 [2:03:48<02:01, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33358/33901 [2:03:49<02:00, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33359/33901 [2:03:49<02:00, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33360/33901 [2:03:49<02:00, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33361/33901 [2:03:49<02:00, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33362/33901 [2:03:50<02:00, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33363/33901 [2:03:50<01:59, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33364/33901 [2:03:50<01:59, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33365/33901 [2:03:51<01:59, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33366/33901 [2:03:51<01:59, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33367/33901 [2:03:51<01:58, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33368/33901 [2:03:51<01:58, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33369/33901 [2:03:52<01:58, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33370/33901 [2:03:52<01:58, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33371/33901 [2:03:52<01:58, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33372/33901 [2:03:52<01:57, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33373/33901 [2:03:53<01:57, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33374/33901 [2:03:53<01:57, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33375/33901 [2:03:53<01:57, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33376/33901 [2:03:54<01:56, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33377/33901 [2:03:54<01:56, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33378/33901 [2:03:54<01:56, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33379/33901 [2:03:54<01:56, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33380/33901 [2:03:55<01:56, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33381/33901 [2:03:55<01:55, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33382/33901 [2:03:55<01:55, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33383/33901 [2:03:55<01:55, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33384/33901 [2:03:56<01:55, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33385/33901 [2:03:56<01:54, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33386/33901 [2:03:56<01:54, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33387/33901 [2:03:57<01:54, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33388/33901 [2:03:57<01:54, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33389/33901 [2:03:57<01:54, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33390/33901 [2:03:57<01:53, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33391/33901 [2:03:58<01:53, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 98%|█████▉| 33392/33901 [2:03:58<01:53, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33393/33901 [2:03:58<01:53, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33394/33901 [2:03:58<01:52, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33395/33901 [2:03:59<01:52, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33396/33901 [2:03:59<01:52, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33397/33901 [2:03:59<01:52, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33398/33901 [2:03:59<01:52, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33399/33901 [2:04:00<01:51, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33400/33901 [2:04:00<01:51, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33401/33901 [2:04:00<01:51, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33402/33901 [2:04:00<01:51, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33403/33901 [2:04:01<01:50, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33404/33901 [2:04:01<01:50, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33405/33901 [2:04:01<01:50, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33406/33901 [2:04:02<01:50, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33407/33901 [2:04:02<01:50, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33408/33901 [2:04:02<01:49, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33409/33901 [2:04:02<01:49, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33410/33901 [2:04:03<01:49, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33411/33901 [2:04:03<01:49, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33412/33901 [2:04:03<01:48, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33413/33901 [2:04:03<01:48, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33414/33901 [2:04:04<01:48, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33415/33901 [2:04:04<01:48, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33416/33901 [2:04:04<01:48, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33417/33901 [2:04:04<01:47, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33418/33901 [2:04:05<01:47, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33419/33901 [2:04:05<01:47, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33420/33901 [2:04:05<01:47, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33421/33901 [2:04:05<01:46, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33422/33901 [2:04:06<01:46, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33423/33901 [2:04:06<01:46, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33424/33901 [2:04:06<01:46, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33425/33901 [2:04:06<01:46, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33426/33901 [2:04:07<01:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33427/33901 [2:04:07<01:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33428/33901 [2:04:07<01:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33429/33901 [2:04:07<01:45, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33430/33901 [2:04:08<01:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33431/33901 [2:04:08<01:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33432/33901 [2:04:08<01:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33433/33901 [2:04:08<01:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33434/33901 [2:04:09<01:44, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33435/33901 [2:04:09<01:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33436/33901 [2:04:09<01:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33437/33901 [2:04:09<01:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33438/33901 [2:04:10<01:43, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33439/33901 [2:04:10<01:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33440/33901 [2:04:10<01:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33441/33901 [2:04:10<01:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33442/33901 [2:04:11<01:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33443/33901 [2:04:11<01:42, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33444/33901 [2:04:11<01:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33445/33901 [2:04:11<01:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33446/33901 [2:04:12<01:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33447/33901 [2:04:12<01:41, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33448/33901 [2:04:12<01:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33449/33901 [2:04:12<01:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33450/33901 [2:04:13<01:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33451/33901 [2:04:13<01:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33452/33901 [2:04:13<01:40, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33453/33901 [2:04:13<01:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33454/33901 [2:04:14<01:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33455/33901 [2:04:14<01:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33456/33901 [2:04:14<01:39, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33457/33901 [2:04:14<01:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33458/33901 [2:04:15<01:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33459/33901 [2:04:15<01:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33460/33901 [2:04:15<01:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33461/33901 [2:04:15<01:38, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33462/33901 [2:04:16<01:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33463/33901 [2:04:16<01:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33464/33901 [2:04:16<01:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33465/33901 [2:04:17<01:37, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33466/33901 [2:04:17<01:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33467/33901 [2:04:17<01:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33468/33901 [2:04:17<01:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33469/33901 [2:04:18<01:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33470/33901 [2:04:18<01:36, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33471/33901 [2:04:18<01:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33472/33901 [2:04:18<01:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33473/33901 [2:04:19<01:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33474/33901 [2:04:19<01:35, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33475/33901 [2:04:19<01:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33476/33901 [2:04:19<01:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33477/33901 [2:04:20<01:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33478/33901 [2:04:20<01:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33479/33901 [2:04:20<01:34, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33480/33901 [2:04:20<01:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33481/33901 [2:04:21<01:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33482/33901 [2:04:21<01:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33483/33901 [2:04:21<01:33, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33484/33901 [2:04:21<01:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33485/33901 [2:04:22<01:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33486/33901 [2:04:22<01:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33487/33901 [2:04:22<01:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33488/33901 [2:04:22<01:32, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33489/33901 [2:04:23<01:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33490/33901 [2:04:23<01:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33491/33901 [2:04:23<01:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33492/33901 [2:04:24<01:31, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33493/33901 [2:04:24<01:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33494/33901 [2:04:24<01:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33495/33901 [2:04:24<01:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33496/33901 [2:04:25<01:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33497/33901 [2:04:25<01:30, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33498/33901 [2:04:25<01:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33499/33901 [2:04:25<01:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33500/33901 [2:04:26<01:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33501/33901 [2:04:26<01:29, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33502/33901 [2:04:26<01:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33503/33901 [2:04:26<01:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33504/33901 [2:04:27<01:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33505/33901 [2:04:27<01:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33506/33901 [2:04:27<01:28, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33507/33901 [2:04:27<01:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33508/33901 [2:04:28<01:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33509/33901 [2:04:28<01:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33510/33901 [2:04:28<01:27, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33511/33901 [2:04:28<01:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33512/33901 [2:04:29<01:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33513/33901 [2:04:29<01:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33514/33901 [2:04:29<01:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33515/33901 [2:04:29<01:26, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33516/33901 [2:04:30<01:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33517/33901 [2:04:30<01:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33518/33901 [2:04:30<01:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33519/33901 [2:04:30<01:25, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33520/33901 [2:04:31<01:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33521/33901 [2:04:31<01:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33522/33901 [2:04:31<01:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33523/33901 [2:04:31<01:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33524/33901 [2:04:32<01:24, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33525/33901 [2:04:32<01:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33526/33901 [2:04:32<01:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33527/33901 [2:04:32<01:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33528/33901 [2:04:33<01:23, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33529/33901 [2:04:33<01:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33530/33901 [2:04:33<01:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33531/33901 [2:04:33<01:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33532/33901 [2:04:34<01:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33533/33901 [2:04:34<01:22, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33534/33901 [2:04:34<01:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33535/33901 [2:04:34<01:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33536/33901 [2:04:35<01:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33537/33901 [2:04:35<01:21, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33538/33901 [2:04:35<01:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33539/33901 [2:04:35<01:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33540/33901 [2:04:36<01:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33541/33901 [2:04:36<01:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33542/33901 [2:04:36<01:20, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33543/33901 [2:04:37<01:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33544/33901 [2:04:37<01:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33545/33901 [2:04:37<01:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33546/33901 [2:04:37<01:19, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33547/33901 [2:04:38<01:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33548/33901 [2:04:38<01:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33549/33901 [2:04:38<01:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33550/33901 [2:04:38<01:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33551/33901 [2:04:39<01:18, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33552/33901 [2:04:39<01:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33553/33901 [2:04:39<01:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33554/33901 [2:04:39<01:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33555/33901 [2:04:40<01:17, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33556/33901 [2:04:40<01:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33557/33901 [2:04:40<01:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33558/33901 [2:04:40<01:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33559/33901 [2:04:41<01:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33560/33901 [2:04:41<01:16, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33561/33901 [2:04:41<01:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33562/33901 [2:04:41<01:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33563/33901 [2:04:42<01:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33564/33901 [2:04:42<01:15, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33565/33901 [2:04:42<01:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33566/33901 [2:04:42<01:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33567/33901 [2:04:43<01:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33568/33901 [2:04:43<01:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33569/33901 [2:04:43<01:14, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33570/33901 [2:04:43<01:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33571/33901 [2:04:44<01:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33572/33901 [2:04:44<01:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33573/33901 [2:04:44<01:13, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33574/33901 [2:04:44<01:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33575/33901 [2:04:45<01:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33576/33901 [2:04:45<01:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33577/33901 [2:04:45<01:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33578/33901 [2:04:46<01:12, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33579/33901 [2:04:46<01:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33580/33901 [2:04:46<01:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33581/33901 [2:04:46<01:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33582/33901 [2:04:47<01:11, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33583/33901 [2:04:47<01:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33584/33901 [2:04:47<01:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33585/33901 [2:04:47<01:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33586/33901 [2:04:48<01:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33587/33901 [2:04:48<01:10, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33588/33901 [2:04:48<01:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33589/33901 [2:04:48<01:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33590/33901 [2:04:49<01:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33591/33901 [2:04:49<01:09, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33592/33901 [2:04:49<01:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33593/33901 [2:04:49<01:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33594/33901 [2:04:50<01:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33595/33901 [2:04:50<01:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33596/33901 [2:04:50<01:08, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33597/33901 [2:04:50<01:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33598/33901 [2:04:51<01:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33599/33901 [2:04:51<01:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33600/33901 [2:04:51<01:07, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33601/33901 [2:04:51<01:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33602/33901 [2:04:52<01:06, 4.49it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33603/33901 [2:04:52<01:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33604/33901 [2:04:52<01:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33605/33901 [2:04:52<01:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33606/33901 [2:04:53<01:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33607/33901 [2:04:53<01:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33608/33901 [2:04:53<01:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33609/33901 [2:04:53<01:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33610/33901 [2:04:54<01:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33611/33901 [2:04:54<01:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33612/33901 [2:04:54<01:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33613/33901 [2:04:54<01:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33614/33901 [2:04:55<01:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33615/33901 [2:04:55<01:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33616/33901 [2:04:55<01:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33617/33901 [2:04:55<01:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33618/33901 [2:04:56<01:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33619/33901 [2:04:56<01:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33620/33901 [2:04:56<01:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33621/33901 [2:04:56<01:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33622/33901 [2:04:57<01:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33623/33901 [2:04:57<01:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33624/33901 [2:04:57<01:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33625/33901 [2:04:57<01:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33626/33901 [2:04:58<01:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33627/33901 [2:04:58<01:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33628/33901 [2:04:58<01:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33629/33901 [2:04:58<01:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33630/33901 [2:04:59<01:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33631/33901 [2:04:59<01:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33632/33901 [2:04:59<00:59, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33633/33901 [2:05:00<00:59, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33634/33901 [2:05:00<00:59, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33635/33901 [2:05:00<00:59, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33636/33901 [2:05:00<00:59, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33637/33901 [2:05:01<00:58, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33638/33901 [2:05:01<00:58, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33639/33901 [2:05:01<00:58, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33640/33901 [2:05:01<00:58, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33641/33901 [2:05:02<00:57, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33642/33901 [2:05:02<00:57, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33643/33901 [2:05:02<00:57, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33644/33901 [2:05:03<00:57, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33645/33901 [2:05:03<00:57, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33646/33901 [2:05:03<00:56, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33647/33901 [2:05:03<00:56, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33648/33901 [2:05:04<00:56, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33649/33901 [2:05:04<00:56, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33650/33901 [2:05:04<00:55, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33651/33901 [2:05:05<00:55, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33652/33901 [2:05:05<00:55, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33653/33901 [2:05:05<00:55, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33654/33901 [2:05:05<00:55, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33655/33901 [2:05:06<00:54, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33656/33901 [2:05:06<00:54, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33657/33901 [2:05:06<00:54, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33658/33901 [2:05:06<00:54, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33659/33901 [2:05:07<00:53, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33660/33901 [2:05:07<00:53, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33661/33901 [2:05:07<00:53, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33662/33901 [2:05:08<00:53, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33663/33901 [2:05:08<00:53, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33664/33901 [2:05:08<00:52, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33665/33901 [2:05:08<00:52, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33666/33901 [2:05:09<00:52, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33667/33901 [2:05:09<00:52, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33668/33901 [2:05:09<00:51, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33669/33901 [2:05:10<00:51, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33670/33901 [2:05:10<00:51, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33671/33901 [2:05:10<00:51, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33672/33901 [2:05:10<00:51, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33673/33901 [2:05:11<00:50, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33674/33901 [2:05:11<00:50, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33675/33901 [2:05:11<00:50, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33676/33901 [2:05:11<00:50, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33677/33901 [2:05:12<00:49, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33678/33901 [2:05:12<00:49, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33679/33901 [2:05:12<00:49, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33680/33901 [2:05:12<00:49, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33681/33901 [2:05:13<00:49, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33682/33901 [2:05:13<00:48, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33683/33901 [2:05:13<00:48, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33684/33901 [2:05:13<00:48, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33685/33901 [2:05:14<00:48, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33686/33901 [2:05:14<00:47, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33687/33901 [2:05:14<00:47, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33688/33901 [2:05:15<00:47, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33689/33901 [2:05:15<00:47, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33690/33901 [2:05:15<00:47, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33691/33901 [2:05:15<00:46, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33692/33901 [2:05:16<00:46, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33693/33901 [2:05:16<00:46, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33694/33901 [2:05:16<00:46, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33695/33901 [2:05:16<00:45, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33696/33901 [2:05:17<00:45, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33697/33901 [2:05:17<00:45, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33698/33901 [2:05:17<00:45, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33699/33901 [2:05:17<00:45, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33700/33901 [2:05:18<00:44, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33701/33901 [2:05:18<00:44, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33702/33901 [2:05:18<00:44, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33703/33901 [2:05:19<00:44, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33704/33901 [2:05:19<00:43, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33705/33901 [2:05:19<00:43, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33706/33901 [2:05:19<00:43, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33707/33901 [2:05:20<00:43, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33708/33901 [2:05:20<00:43, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33709/33901 [2:05:20<00:42, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33710/33901 [2:05:21<00:42, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33711/33901 [2:05:21<00:42, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33712/33901 [2:05:21<00:42, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33713/33901 [2:05:21<00:41, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33714/33901 [2:05:22<00:41, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33715/33901 [2:05:22<00:41, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33716/33901 [2:05:22<00:41, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33717/33901 [2:05:22<00:41, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33718/33901 [2:05:23<00:40, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33719/33901 [2:05:23<00:40, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33720/33901 [2:05:23<00:40, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33721/33901 [2:05:24<00:40, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33722/33901 [2:05:24<00:39, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33723/33901 [2:05:24<00:39, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33724/33901 [2:05:24<00:39, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33725/33901 [2:05:25<00:39, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33726/33901 [2:05:25<00:39, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33727/33901 [2:05:25<00:38, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33728/33901 [2:05:25<00:38, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33729/33901 [2:05:26<00:38, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33730/33901 [2:05:26<00:38, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 99%|█████▉| 33731/33901 [2:05:26<00:37, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33732/33901 [2:05:27<00:37, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33733/33901 [2:05:27<00:37, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33734/33901 [2:05:27<00:37, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33735/33901 [2:05:27<00:37, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33736/33901 [2:05:28<00:36, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33737/33901 [2:05:28<00:36, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33738/33901 [2:05:28<00:36, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33739/33901 [2:05:28<00:36, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33740/33901 [2:05:29<00:35, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33741/33901 [2:05:29<00:35, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33742/33901 [2:05:29<00:35, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33743/33901 [2:05:30<00:35, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33744/33901 [2:05:30<00:35, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33745/33901 [2:05:30<00:34, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33746/33901 [2:05:30<00:34, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33747/33901 [2:05:31<00:34, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33748/33901 [2:05:31<00:34, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33749/33901 [2:05:31<00:33, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33750/33901 [2:05:31<00:33, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33751/33901 [2:05:32<00:33, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33752/33901 [2:05:32<00:33, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33753/33901 [2:05:32<00:33, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33754/33901 [2:05:32<00:32, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33755/33901 [2:05:33<00:32, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33756/33901 [2:05:33<00:32, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33757/33901 [2:05:33<00:32, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33758/33901 [2:05:33<00:31, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33759/33901 [2:05:34<00:31, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33760/33901 [2:05:34<00:31, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33761/33901 [2:05:34<00:31, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33762/33901 [2:05:34<00:31, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33763/33901 [2:05:35<00:30, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33764/33901 [2:05:35<00:30, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33765/33901 [2:05:35<00:30, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33766/33901 [2:05:35<00:30, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33767/33901 [2:05:36<00:29, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33768/33901 [2:05:36<00:29, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33769/33901 [2:05:36<00:29, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33770/33901 [2:05:36<00:29, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33771/33901 [2:05:37<00:29, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33772/33901 [2:05:37<00:28, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33773/33901 [2:05:37<00:28, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33774/33901 [2:05:37<00:28, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33775/33901 [2:05:38<00:28, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33776/33901 [2:05:38<00:27, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33777/33901 [2:05:38<00:27, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33778/33901 [2:05:38<00:27, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33779/33901 [2:05:39<00:27, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33780/33901 [2:05:39<00:27, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33781/33901 [2:05:39<00:26, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33782/33901 [2:05:39<00:26, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33783/33901 [2:05:40<00:26, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33784/33901 [2:05:40<00:26, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33785/33901 [2:05:40<00:25, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33786/33901 [2:05:40<00:25, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33787/33901 [2:05:41<00:25, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33788/33901 [2:05:41<00:25, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33789/33901 [2:05:41<00:24, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33790/33901 [2:05:41<00:24, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33791/33901 [2:05:42<00:24, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33792/33901 [2:05:42<00:24, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33793/33901 [2:05:42<00:24, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33794/33901 [2:05:43<00:23, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33795/33901 [2:05:43<00:23, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33796/33901 [2:05:43<00:23, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33797/33901 [2:05:43<00:23, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33798/33901 [2:05:44<00:22, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33799/33901 [2:05:44<00:22, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33800/33901 [2:05:44<00:22, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33801/33901 [2:05:44<00:22, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33802/33901 [2:05:45<00:22, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33803/33901 [2:05:45<00:21, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33804/33901 [2:05:45<00:21, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33805/33901 [2:05:45<00:21, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33806/33901 [2:05:46<00:21, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33807/33901 [2:05:46<00:20, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33808/33901 [2:05:46<00:20, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33809/33901 [2:05:46<00:20, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33810/33901 [2:05:47<00:20, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33811/33901 [2:05:47<00:20, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33812/33901 [2:05:47<00:19, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33813/33901 [2:05:47<00:19, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33814/33901 [2:05:48<00:19, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33815/33901 [2:05:48<00:19, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33816/33901 [2:05:48<00:18, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33817/33901 [2:05:48<00:18, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33818/33901 [2:05:49<00:18, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33819/33901 [2:05:49<00:18, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33820/33901 [2:05:49<00:18, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33821/33901 [2:05:49<00:17, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33822/33901 [2:05:50<00:17, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33823/33901 [2:05:50<00:17, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33824/33901 [2:05:50<00:17, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33825/33901 [2:05:50<00:16, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33826/33901 [2:05:51<00:16, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33827/33901 [2:05:51<00:16, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33828/33901 [2:05:51<00:16, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33829/33901 [2:05:51<00:16, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33830/33901 [2:05:52<00:15, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33831/33901 [2:05:52<00:15, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33832/33901 [2:05:52<00:15, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33833/33901 [2:05:53<00:15, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33834/33901 [2:05:53<00:14, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33835/33901 [2:05:53<00:14, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33836/33901 [2:05:53<00:14, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33837/33901 [2:05:54<00:14, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33838/33901 [2:05:54<00:14, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33839/33901 [2:05:54<00:13, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33840/33901 [2:05:54<00:13, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33841/33901 [2:05:55<00:13, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33842/33901 [2:05:55<00:13, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33843/33901 [2:05:55<00:12, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33844/33901 [2:05:55<00:12, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33845/33901 [2:05:56<00:12, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33846/33901 [2:05:56<00:12, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33847/33901 [2:05:56<00:12, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33848/33901 [2:05:56<00:11, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33849/33901 [2:05:57<00:11, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33850/33901 [2:05:57<00:11, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33851/33901 [2:05:57<00:11, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33852/33901 [2:05:57<00:10, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33853/33901 [2:05:58<00:10, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33854/33901 [2:05:58<00:10, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33855/33901 [2:05:58<00:10, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33856/33901 [2:05:58<00:10, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33857/33901 [2:05:59<00:09, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33858/33901 [2:05:59<00:09, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33859/33901 [2:05:59<00:09, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33860/33901 [2:05:59<00:09, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33861/33901 [2:06:00<00:08, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33862/33901 [2:06:00<00:08, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33863/33901 [2:06:00<00:08, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33864/33901 [2:06:00<00:08, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33865/33901 [2:06:01<00:08, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33866/33901 [2:06:01<00:07, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33867/33901 [2:06:01<00:07, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33868/33901 [2:06:01<00:07, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33869/33901 [2:06:02<00:07, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33870/33901 [2:06:02<00:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33871/33901 [2:06:02<00:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33872/33901 [2:06:02<00:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33873/33901 [2:06:03<00:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33874/33901 [2:06:03<00:06, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33875/33901 [2:06:03<00:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33876/33901 [2:06:03<00:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33877/33901 [2:06:04<00:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33878/33901 [2:06:04<00:05, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33879/33901 [2:06:04<00:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33880/33901 [2:06:04<00:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33881/33901 [2:06:05<00:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33882/33901 [2:06:05<00:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33883/33901 [2:06:05<00:04, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33884/33901 [2:06:06<00:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33885/33901 [2:06:06<00:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33886/33901 [2:06:06<00:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33887/33901 [2:06:06<00:03, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33888/33901 [2:06:07<00:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33889/33901 [2:06:07<00:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33890/33901 [2:06:07<00:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33891/33901 [2:06:07<00:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33892/33901 [2:06:08<00:02, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33893/33901 [2:06:08<00:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33894/33901 [2:06:08<00:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33895/33901 [2:06:08<00:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33896/33901 [2:06:09<00:01, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33897/33901 [2:06:09<00:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33898/33901 [2:06:09<00:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33899/33901 [2:06:09<00:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|█████▉| 33900/33901 [2:06:10<00:00, 4.48it/s, loss=1.51, v_num=0]
Epoch 0: 100%|██████| 33901/33901 [2:06:10<00:00, 4.48it/s, loss=1.51, v_num=0]
The test features are normalized.
The distance matrix is processed by re-ranking.
Execution status: FAIL
2024-08-20 20:33:19,025 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 337: Stopping container.
Below is the configuration file:
results_dir: "/results/market1501"
encryption_key: nvidia_tao
model:
backbone: resnet_50
last_stride: 1
pretrain_choice: imagenet
pretrained_model_path: "/model/resnet50_pretrained.pth"
input_channels: 3
input_width: 128
input_height: 256
neck: bnneck
feat_dim: 256
neck_feat: after
metric_loss_type: triplet
with_center_loss: False
with_flip_feature: False
label_smooth: True
dataset:
train_dataset_dir: "/data/sample_train"
test_dataset_dir: "/data/sample_test"
query_dataset_dir: "/data/sample_query"
num_classes: 74295
batch_size: 64
val_batch_size: 128
num_workers: 1
pixel_mean: [0.485, 0.456, 0.406]
pixel_std: [0.226, 0.226, 0.226]
padding: 10
prob: 0.5
re_prob: 0.5
sampler: softmax_triplet
num_instances: 4
re_ranking:
re_ranking: True
k1: 20
k2: 6
lambda_value: 0.3
train:
optim:
#lr_steps: [40, 70]
gamma: 0.1
bias_lr_factor: 1
weight_decay: 0.0005
weight_decay_bias: 0.0005
warmup_factor: 0.01
warmup_iters: 10
warmup_method: linear
base_lr: 0.00035
momentum: 0.9
center_loss_weight: 0.0005
center_lr: 0.5
triplet_loss_margin: 0.3
num_epochs: 120
checkpoint_interval: 1
