Hi
I’m trying make a Read-only rootfs on Emmc by overlayroot
I can successfully make it on Xavier NX and Nano
But it failed on AGX Xavier
The step reference here:
Could you help to check why it didn’t work on AGX Xavier?
Hi
Hi zax,
Are you using the devkit or custom board for AGX Xavier?
It seems the 3-rd party tool and we didn’t verify it before.
What issue do you hit now? Could you share any logs?
Hi KevinFFF,
I tried both custom board and devkit, the result is the same
Jetpack4.6.2 is not work, but Jetpack4.6 is ok just test recently
If there’s any official way to make a read-only rootfs, please help to tell me
The github use ovrlayroot, and the script it actually do the same things as Protecting the Root Filesystem on Ubuntu with Overlayroot
I’ve just referred to the steps in your link and verified it could work for AGX Xavier devkit with JP4.6.4 (L4T R32.7.4).
Please verify with R32.7.4 and share the logs.
Hi KevinFFF,
Thanks for help, JP4.6.4 works
But I need your confirm that AGX Xavier can’t work for read-only rootfs on JP4.6.2 to persuade our customer
Could you help to check again on JP4.6.2?
And if possible, please tell me why it is not working
Normally, we would only verify with the latest release. (for R32, it is R32.7.4).
Do you have any requirement for JP4.6.2?
There might be several fixes and update between them.
Is there any release note mention about these?
Could you try to modify the in /etc/fstab from defaults
to ro
and reboot the board to make rootfs read-only?
Sorry late for reply
After modified the in /etc/fstab from defaults to ro and reboot
The system showed many error message while booting, then stock
I can enter the system through uart debug port
And check the rootfs is ro, but it seems not a good solution
mount.log (2.5 KB)
Since overlayroot would mount your partition at /media/root-ro
rather than changing the whole rootfs to read-only as you modified in /etc/fstab
I would suggest just using the latest R32.7.4 for your use case.
okay
Thanks for help
