• Hardware Platform
Jetson AGX Xavier • DeepStream Version
6.0 • JetPack Version (valid for Jetson only)
4.6.1 • TensorRT Version
ii libnvinfer-bin 8.2.1-1+cuda10.2 arm64 TensorRT binaries
ii libnvinfer-dev 8.2.1-1+cuda10.2 arm64 TensorRT development libraries and headers
ii libnvinfer-doc 8.2.1-1+cuda10.2 all TensorRT documentation
ii libnvinfer-plugin-dev 8.2.1-1+cuda10.2 arm64 TensorRT plugin libraries
ii libnvinfer-plugin8 8.2.1-1+cuda10.2 arm64 TensorRT plugin libraries
ii libnvinfer-samples 8.2.1-1+cuda10.2 all TensorRT samples
ii libnvinfer8 8.2.1-1+cuda10.2 arm64 TensorRT runtime libraries
ii python3-libnvinfer 8.2.1-1+cuda10.2 arm64 Python 3 bindings for TensorRT
ii python3-libnvinfer-dev 8.2.1-1+cuda10.2 arm64 Python 3 development package for TensorRT
question, bug?, limitation? • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Convert to ONNX (using the guide provided in pytorch docs)
Use the converted model in deepstream Jetson Xavier
P.S
Apologies I don’t have the files with me at the moment.
Thanks a lot for getting back to me.
This is how I ended up here.
I made a pytorch model and got an ONNX file
[Download the notebook here] pytorch_to_onnx_to_nvidia_forum.ipynb (377.6 KB)
Also I made a gist here so you can see the rendered notebook (This was run in an nvidia DGX station A100)
The model I made by that is this ssd300-ganindu_test_gpu_fp16.onnx (43.7 MB)
then I wanted to make this into an engine file. so I followed instructions [here] (Gst-nvinfer — DeepStream 6.0 Release documentation) to make a pgie file fr a custom parsing function.
(This pattern works with my other deepstream python apps so I’m sure my python code is fine )
Then let’s look into a cpp parsing function
/* Template */
extern "C" bool MyCustomParsingFunction(std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objectList);
/* function */
for (unsigned int i = 0; i < outputLayersInfo.size(); i++)
NvDsInferDimsCHW bboxLayerDims_temp;
getDimsCHWFromDims(bboxLayerDims_temp, outputLayersInfo[i].inferDims);
std::cout << "Layer name " << outputLayersInfo[i].layerName << " index = " << i << " channels " << bboxLayerDims_temp.c << " height " << bboxLayerDims_temp.h << " width " << bboxLayerDims_temp.w << "\n";
/* then I find the index of my bbox layer and save it in my_class_scores_layer_index */
const NvDsInferLayerInfo *scoreLayer = &outputLayersInfo[my_bbx_class_scores_index ]; /* I get a pointer to class_scores layer which according to netron and the ` getDimsCHWFromDims(bboxLayerDims_temp, outputLayersInfo[i].inferDims);` should be 1x81x8732 */
/* At this point how do I access an arbitrary element of that tensor? */
return 0;
It seems that after that point my attempts to access in my multi dimensionalclass_scores fails miserably.
To further clarify, I haven’t consciously done any non maximum suppression as the class score are still un normalised and needs to be soft maxed etc. so I think the output tensors should be full sized eg. “scores” to be 81 x n_bbox long. (But I can’t index that length without getting overruns) I’m sure I’m doing something wrong here because these type of operations are bread and butter for deepstream. So apologies in advance if it’s something very silly 🙏
