Regarding the white balance issue with the IMX219 camera
Hello, I tried to use the Orin NX to connect two IMX219 cameras. Since I used a custom carrier board, I rewrote the device tree file. Currently, the camera can capture images, but there are some color issues—the edges of the images have a noticeable red tint. I checked some similar issues on the forum, and it seems it may be related to the badge property under the tcp node. I have attached my device tree file. Do you know why this issue might be occurring?
/dts-v1/;
/plugin/;
	overlay-name = "Camera IMX219-02 starsea";
	jetson-header-name = "Jetson 24pin CSI Connector";
	compatible = "nvidia,p3768-0000+p3767-0000", "nvidia,p3768-0000+p3767-0001", "nvidia,p3768-0000+p3767-0003", "nvidia,p3768-0000+p3767-0004", "nvidia,p3768-0000+p3767-0005";
	fragment@0 {
		target = <&cam_i2c>;
		__overlay__ {
			#address-cells = <0x01>;
			#size-cells = <0x00>;
			status = "okay";
			tca9548_77:tca9548@77{
				compatible = "nxp,pca9548";
				reg = <0x77>;
				#address-cells = <1>;
				#size-cells = <0>;
				i2c-mux-idle-disconnect;
				skip_mux_detect;
				force_bus_start = <0x1e>;
				status = "okay";
				i2c_cam0:i2c@0 {
					reg = <0>;
					i2c-mux,deselect-on-exit;
					#size-cells = <0>;
					status = "okay";
					NX4_imx219_cam0: imx219_a@10 {
						compatible = "sony,imx219";
						/* I2C device address */
						reg = <0x10>;
						/* V4L2 device node location */
						devnode = "video0";
						/* Physical dimensions of sensor */
						physical_w = "3.680";
						physical_h = "2.760";
						sensor_model = "imx219";
						use_sensor_mode_id = "true";
						reset-gpios = <&tca9534_38 0 0>;
						status = "okay";
						mode0 { /* IMX219_MODE_3280x2464_21FPS */
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							discontinuous_clk = "yes";
							dpcm_enable = "false";
							cil_settletime = "0";
							lane_polarity = "6";
							active_w = "3280";
							active_h = "2464";
							mode_type = "bayer";
							pixel_phase = "rggb";
							csi_pixel_bit_depth = "10";
							readout_orientation = "90";
							line_length = "3448";
							inherent_gain = "1";
							mclk_multiplier = "9.33";
							pix_clk_hz = "182400000";
							gain_factor = "16";
							framerate_factor = "1000000";
							exposure_factor = "1000000";
							min_gain_val = "16"; /* 1.00x */
							max_gain_val = "170"; /* 10.66x */
							step_gain_val = "1";
							default_gain = "16"; /* 1.00x */
							min_hdr_ratio = "1";
							max_hdr_ratio = "1";
							min_framerate = "2000000"; /* 2.0 fps */
							max_framerate = "21000000"; /* 21.0 fps */
							step_framerate = "1";
							default_framerate = "21000000"; /* 21.0 fps */
							min_exp_time = "13"; /* us */
							max_exp_time = "683709"; /* us */
							step_exp_time = "1";
							default_exp_time = "2495"; /* us */
							embedded_metadata_height = "2";
						mode1 { /* IMX219_MODE_3280x1848_28FPS */
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "3280";
							active_h = "1848";
							gain_factor = "16";
							max_framerate = "28000000"; /* 28.0 fps */
							default_framerate = "28000000"; /* 28.0 fps */
						mode2 { /* IMX219_MODE_1920x1080_30FPS */
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1920";
							active_h = "1080";
							gain_factor = "16";
							max_framerate = "30000000"; /* 30.0 fps */
							default_framerate = "30000000"; /* 30.0 fps */
						mode3 { /* IMX219_MODE_1640x1232_30FPS */
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1640";
							active_h = "1232";
							gain_factor = "16";
							max_framerate = "30000000"; /* 60.0 fps */
							default_framerate = "30000000"; /* 60.0 fps */
						mode4 { /* IMX219_MODE_1280x720_60FPS */
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1280";
							active_h = "720";
							gain_factor = "16";
							max_framerate = "60000000"; /* 60.0 fps */
							default_framerate = "60000000"; /* 60.0 fps */
						ports {
							#size-cells = <0>;
							port@0 {
								reg = <0>;
								NX4_imx219_out0: endpoint {
									port-index = <0>;
									bus-width = <2>;
									remote-endpoint = <&rbpcv3_imx477_csi_in0>;
				i2c_cam1:i2c@1 {
					reg = <1>;
					#size-cells = <0>;
					status = "okay";
					NX4_imx219_cam1: imx219_b@10 {
						reg = <0x10>;
						devnode = "video1";
						reset-gpios = <&tca9534_38 1 0>;
						status = "okay";
							mclk_khz = "24000";
							num_lanes = "2";
							tegra_sinterface = "serial_b";
							phy_mode = "DPHY";
							active_w = "3280";
							active_h = "2464";
							gain_factor = "16";
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "3280";
							active_h = "1848";
							gain_factor = "16";
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1920";
							active_h = "1080";
							gain_factor = "16";
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1640";
							active_h = "1232";
							gain_factor = "16";
							mclk_khz = "24000";
							num_lanes = "2";
							phy_mode = "DPHY";
							active_w = "1280";
							active_h = "720";
							gain_factor = "16";
						ports {
							#size-cells = <0>;
							port@0 {
								reg = <0>;
								NX4_imx219_out1: endpoint {
									port-index = <1>;
									bus-width = <2>;
									remote-endpoint = <&rbpcv2_imx219_csi_in1>;
				i2c_gpio:i2c@6 {
					reg = <0x06>;
					status = "okay";
					tca9534_38:tca9534@38 {
						compatible = "nxp,pca9534";
						reg = <0x38>;
						gpio-controller;
						#gpio-cells = <0x02>;
						status = "okay";
						tca9534_38_out {
							status = "okay";
							gpio-hog;
							output-low;
							gpios = <0x00 0x00 0x01 0x00 0x02 0x00 0x03 0x00 0x04 0x00>;
							label = "cam0-pwdn","cam1-pwdn","cam2-pwdn","cam3-pwdn","test-pwdn";
				i2c_eeprom:i2c@7 {
					reg = <0x07>;
					status = "okay";
					eeprom_57:eeprom@57 {
						compatible = "atmel,at24c16";
						reg = <0x57>;
						status = "okay";
	/* nvcsi@15a00000 setting */
	fragment@1 {
		target = <&rbpcv3_imx477_vi_in0>;
		__overlay__ {
			status = "okay";
			port-index = <0>;
			bus-width = <2>;
			remote-endpoint = <&rbpcv3_imx477_csi_out0>;
	fragment@2 {
		target = <&rbpcv3_imx477_csi_in0>;
		__overlay__ {
			status = "okay";
			port-index = <0>;
			bus-width = <2>;
			remote-endpoint = <&NX4_imx219_out0>;
	fragment@3 {
		target = <&rbpcv3_imx477_csi_out0>;
		__overlay__ {
			status = "okay";
			remote-endpoint = <&rbpcv3_imx477_vi_in0>;
	fragment@4 {
		target = <&rbpcv2_imx219_vi_in1>;
		__overlay__ {
			status = "okay";
			port-index = <1>;
			bus-width = <2>;
			remote-endpoint = <&rbpcv2_imx219_csi_out1>;
	fragment@5 {
		target = <&rbpcv2_imx219_csi_in1>;
		__overlay__ {
			status = "okay";
			port-index = <1>;
			bus-width = <2>;
			remote-endpoint = <&NX4_imx219_out1>;
	fragment@6 {
		target = <&rbpcv2_imx219_csi_out1>;
		__overlay__ {
			status = "okay";
			remote-endpoint = <&rbpcv2_imx219_vi_in1>;
	/* tegra-camera-platform setting */
	fragment@7 {
		target = <&cam_module0>;
		__overlay__ {
			badge = "imx219_front_RBP194";
			position = "front";
			orientation = "1";
			status = "okay";
	fragment@8 {
		target = <&cam_module0_drivernode0>;
		__overlay__ {
			status = "okay";
			pcl_id = "v4l2_sensor";
			devname = "imx219 30-0010";
			proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@0/imx219_a@10";
	fragment@10 {
		target = <&cam_module1>;
		__overlay__ {
			badge = "imx219_rear_RBP194";
			position = "rear";
			orientation = "1";
			status = "okay";
	fragment@11 {
		target = <&cam_module1_drivernode0>;
		__overlay__ {
			status = "okay";
			devname = "imx219 31-0010";
			proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@1/imx219_b@10";
	fragment@13 {
		target = <&vi_port0>;
		__overlay__ {
			status = "okay";
	fragment@14 {
		target = <&vi_port1>;
		__overlay__ {
			status = "okay";
	fragment@20 {
		target = <&i2c_0>;
		__overlay__ {
			status = "disabled";
	fragment@21 {
		target = <&i2c_1>;
		__overlay__ {
	fragment@22 {
		target = <&imx219_cam0>;
		__overlay__ {
	fragment@23 {
		target = <&imx219_cam1>;
		__overlay__ {
	fragment@24 {
		target = <&imx477_cam0>;
		__overlay__ {
	fragment@25 {
		target = <&imx477_cam1>;
		__overlay__ {
	fragment@26 {
		target = <&rbpcv2_imx219_out0>;
		__overlay__ {
	fragment@27 {
		target = <&rbpcv2_imx219_out1>;
		__overlay__ {
	fragment@28 {
		target = <&rbpcv3_imx477_out0>;
		__overlay__ {
	fragment@29 {
		target = <&rbpcv3_imx477_out1>;
		__overlay__ {
	fragment@30 {
		target-path = "/";
		__overlay__ {
			aliases{
				i2c30 = "/i2c@3180000/tca9548@77/i2c@0";
				i2c31 = "/i2c@3180000/tca9548@77/i2c@1";
				i2c32 = "/i2c@3180000/tca9548@77/i2c@2";
	fragment@31 {
		target-path = "/";
		__overlay__ {
			cam_i2cmux{
The badge is the information to load correct ISP configuration.
I have a general understanding of the function of the badge property, so I referred to the naming of the badge property in the tegra234-camera-rbpcv2-imx219.dtsi file. This is the naming I adopted for the badge property. Do you think there is anything inappropriate with it? Or, do you think there might be other potential issues causing the color problem in the camera images?
	fragment@7 {
		__overlay__ {
			position = "front";
			orientation = "1";
			status = "okay";
	fragment@8 {
		__overlay__ {
			status = "okay";
	fragment@10 {
		__overlay__ {
			position = "rear";
			orientation = "1";
			status = "okay";
	fragment@11 {
		__overlay__ {
			status = "okay";
If the camera module is different with the PI V2 IMX219 that couldn’t use the the same reference sensor’s badge info.
You can modify RBP194 to any others random strings to try.
