Replicating PyTorch image pre-processing into TRT DeepStream
I recently posted this post on the TensorRT forums and was referred here.
Currently my I think that the problem is due to the different image pre-processing from the PyTorch model and when running on TRT.
How do I find the values I use in my spec file for net-scale-factor, offsets or other variables to best replicate the image preprocessing used in the PyTorch program?
• Hardware Platform (Jetson / GPU) = Jetson
• DeepStream Version = 5.1
• JetPack Version (valid for Jetson only) = jetson-nano-jp451-sd-card-image
• TensorRT Version = 7.1.3-1
• Issue Type( questions, new requirements, bugs) = questions
Please find below’s topic for the information:
Unfortunately, when I try to use those values I get outputs that are much larger than expected and are not normalised as they should be.
I am trying to replicate this from torchvision:
torchvision.transforms.Compose([torchvision.transforms.ToTensor(),
                                           torchvision.transforms.Normalize(mean=[0.43476477, 0.44504763, 0.43252817],
        std=[0.20490805, 0.19712372, 0.20312176]),
                                           torchvision.transforms.Resize(540, 960)
                                           ])  # normalize to (-1, 1)
Could you share the details about your preprocessing so we can check?
