Request for NVIDIA NIM API Rate Limit Increase (40 → 200 RPM) – Autonomous Multi-Agent Document Intelligence Systema
Hello NVIDIA Support Team,
I am requesting a rate limit increase for my NVIDIA NIM API account to support an agentic project I am actively developing — an Autonomous Document Intelligence Agent that processes large batches of mixed-media documents (PDFs, scanned images, audio memos) with zero human intervention.
Account Details:
  • Account Email: selvarajamrith958@gmail.com
  • API Key ID (Last 4 chars): Fi7K
  • Current Limit: 40 RPM (shared pool)
  • Requested Limit: 200 RPM
  • Models in use: gemma-3n-e4b-it, gemma-3n-e2b-it
Project Overview:
The system is a fully autonomous multi-agent pipeline designed to ingest a folder of heterogeneous documents and produce a structured intelligence report — no human in the loop at any stage.
The agent architecture works as follows:
  1. Orchestrator Agent receives a document batch (e.g. 15 mixed PDFs, images, audio memos) and spawns one Worker Agent per document simultaneously
  2. Worker Agents call Gemma 3n E4B for each document:
    • PDF pages are converted to images → vision call per page
    • Audio memos → direct audio input to Gemma 3n E4B
    • Each worker extracts structured entities, key facts, relationships
  3. Cross-Reference Agent receives all worker outputs → calls NIM to identify contradictions, overlaps, and connections across documents
  4. Synthesis Agent makes a final NIM call to compile all findings into a structured report with confidence scores
Why 40 RPM is insufficient:
A single batch of 15 documents (conservative estimate, ~2 pages each) generates the following NIM calls:
  • 30 vision calls from Worker Agents (one per PDF page, running concurrently)
  • 5 audio calls for voice memos
  • 3-5 cross-reference calls from the Cross-Reference Agent
  • 1 final synthesis call
Total: ~40 NIM calls per batch, all firing within a 60-second window due to the parallel worker architecture. This instantly saturates the 40 RPM shared pool, causing 429 errors that cascade through the entire agent network and stall the pipeline completely.
Gemma 3n E4B is specifically chosen because it is one of the very few models that handles text, image, and audio natively in a single model — making it the only viable choice for this mixed-media agentic workflow. There is no equivalent free-tier alternative that covers all three modalities.
Increasing the limit to 200 RPM would allow the agent network to process document batches reliably and concurrently without mid-pipeline failures.
Thank you for considering this request. Happy to provide additional technical details if needed.
