Hi NVIDIA team,
I’m running training workloads on a DGX Spark (GB10, compute capability 12.1 / sm_121) and observing a significant per-epoch throughput gap compared to a discrete consumer GPU (RTX
4080, sm_89) on the same code, dataset, and PyTorch version. I’d like to formally request that cuDNN/cuBLAS ship sm_121-tuned kernel paths, and ask whether there is any public
roadmap commitment for this.
Hardware and software
- DGX Spark — NVIDIA GB10 Blackwell, compute capability 12.1 (sm_121), 119 GB unified LPDDR5X
- Reference comparator — NVIDIA GeForce RTX 4080, compute capability 8.9 (sm_89), 16 GB GDDR6X
- Driver: NVIDIA 570.x series
- CUDA toolkit: 12.8
- PyTorch: stable channel (built with TORCH_CUDA_ARCH_LIST ending at sm_120 / compute_120 — no sm_121 binaries shipped as of this writing)
- cuDNN: 9.x bundled with PyTorch
- Workload: medium-scale audio classification training (multi-label CNN, EfficientNet-B0 backbone via timm, bfloat16 amp, batch size 64)
Observed behavior
│ GPU │ Per-epoch wall-clock │ Ratio vs sm_89 4080 │
│ RTX 4080 (sm_89) │ ~18.5 min │ 1.0× (reference) │
│ DGX Spark GB10 (sm_121) │ ~52 min projected │ ~2.8× slower │
A second prior workload (EfficientNetV2-S, same family) measured an even wider gap of ~4.2× slower on the same DGX Spark (13.4 min/epoch vs 3.2 min/epoch on the same 4080, same
code, same seed, same data).
The GPU itself appears healthy — nvidia-smi shows brief utilization spikes to 96% during kernel execution windows, indicating the GPU IS doing real work when batches arrive. The gap
is not a hardware fault.
What I believe is happening
Per public discussion (and PyTorch’s own arch-list at build time), PyTorch stable currently ships sm_120 binaries. GB10 is sm_121 — a different SM revision from sm_120 (RTX
50-series consumer Blackwell). On GB10:
- cuDNN convolution kernels and cuBLAS GEMMs fall back to generic / sm_120 paths rather than sm_121-tuned ones.
- NVRTC JIT compilation targeting sm_121 fails outright (no compiler support visible at our toolchain version).
- Triton heuristics use generic paths.
The combination of these — plus the GB10’s lower memory bandwidth (~273 GB/s LPDDR5X vs ~717 GB/s GDDR6X on the 4080) — appears to dominate throughput on memory-bound depthwise /
inverted-bottleneck convolutions, which are common in modern CNN backbones.
My ask
- Is there a committed roadmap for sm_121-tuned kernels in cuDNN/cuBLAS? Public posts I’ve seen from NVIDIA representatives acknowledged a DGX Spark training-throughput regression
but stopped short of committing a timeline. A roadmap commitment — even a vague quarter — would help DGX Spark customers plan around this. - Is there a near-term workaround on the toolchain side? For example: an NGC PyTorch container with internal cuDNN tunings that aren’t yet in the public release, a CUDA 13.x
preview with broader compute-capability coverage, or a recommended environment configuration. - Should DGX Spark customers expect the existing sm_120 fallback path to be the long-term plan? If yes, that’s a useful clarification — it would inform purchasing and capacity
decisions. If no, what’s the rough horizon?
Context
I understand DGX Spark is positioned as a unified-memory development workstation and large-model inference rig, not primarily as a training accelerator. That’s a reasonable product
framing, but the current gap means many real-world training workloads (CV backbones, audio classifiers, anything memory-bound) run materially slower than on a consumer 4080 — and a
sm_120-tuned cuDNN release would presumably close most of that gap without any hardware change.
A formal roadmap commitment, or an NGC-container path, would let customers like me plan deployment and budgeting decisions with less uncertainty.
Thanks in advance for any update you can share.
