Request: Increase MEMIC allocation on ConnectX-6
Dear NVIDIA Support,
I am a researcher working with on-NIC device memory (MEMIC) on the ConnectX-6, and I am seeking guidance on whether the MEMIC allocation can be increased beyond the current firmware-enforced limit on our card.
Device Information
Field Value
Device Type ConnectX-6
Part Number MCX653106A-HDA_Ax
Description ConnectX-6 VPI, HDR IB (200Gb/s) and 200GbE, dual-port QSFP56, PCIe4.0 x16
PSID MT_0000000225
PCI Address 0000:ca:00.0 (IB) / 0000:ca:00.1 (ETH)
Firmware 20.43.8002 (latest available, updated from 20.43.3608)
Base GUID e8eb:d303:003b:ecb7
The Problem
The firmware caps MEMIC at 256 KB total, organized as 128 KB per physical function:
MEMIC_SIZE_LIMIT = _256KB(1)   ← firmware max = 1, rejects _512KB(2) or _1024KB(3)
MEMIC_BAR_SIZE   = 0           ← firmware max = 0, rejects 1
Measured via ibv_alloc_dm:
Function max_dm_size Allocatable
mlx5_0 (IB) 128 KB 128 KB
mlx5_1 (ETH) 128 KB 128 KB
Total — 256 KB
MEMIC is per-function (not shared): we verified that mlx5_1 still gets 128 KB while mlx5_0 holds its full pool via a concurrent allocation test.
What We Have Tried
  1. mlxconfig set MEMIC_SIZE_LIMIT=_512KB → rejected: “value is larger than maximum allowed 1”
  2. mlxconfig set MEMIC_BAR_SIZE=1 → rejected: “value is larger than maximum allowed 0”
  3. Firmware update 20.43.3608 → 20.43.8002 → no change in limits
  4. SR-IOV: SRIOV_EN=1, NUM_OF_VFS=4 accepted in firmware, but PCIe SR-IOV capability is not exposed by this SKU (no sriov_totalvfs in sysfs, and lspci shows no SR-IOV extended capability on either function)
  5. Raw TLV / set_raw override → firmware validates at boot and rejects out-of-range values
This is consistent with another user’s experience reported on the NVIDIA Developer Forum: How much device memory can I allocate in ConnectX-6?
Our Goal
We are conducting research on using MEMIC as a low-latency on-NIC cache for distributed machine learning workloads. 256 KB (128 KB/function) is sufficient for a proof-of-concept, but larger MEMIC — ideally 1 MB or more — would significantly broaden the applicability of our approach.
We understand that the ConnectX-6 ASIC has approximately 4 MB of on-chip SRAM, and that most of it is reserved for steering, QP/CQ/WQE contexts. We are asking whether a larger portion of that SRAM can be re-allocated to the MEMIC pool on this specific SKU.
Our Questions
  1. Is there a firmware build — official or custom — that raises MEMIC_SIZE_LIMIT above _256KB (index 1) for PSID MT_0000000225?
  2. Is there a way to enable MEMIC_BAR_SIZE=1 on this card, effectively doubling the addressable MEMIC window (from 256 KB × 2^0 = 256 KB to 256 KB × 2^1 = 512 KB)?
  3. Does SR-IOV on this SKU require a different firmware image, or is PCIe SR-IOV simply not supported on the MCX653106A-HDA_Ax?
  4. If the above are not possible on this SKU, can you recommend a ConnectX-6 (or ConnectX-7) SKU that exposes 1 MB or more of user-allocatable MEMIC?
Context
This is an academic research project. We are happy to sign any required NDAs and would greatly appreciate any guidance — even if the answer is simply “this SKU cannot allocate more MEMIC.” Understanding the hardware’s ceiling is valuable for our paper.
Thank you for your time.
Best regards,
Steven
Hi Steven,
As far as I know, the MEMIC allocation can’t be increased.
Thanks,
Suo
