Request: Replace GLM-5 with GLM-5.1 from Z-ai on NIM
Hi NVIDIA team,
I’d like to request that GLM-5 currently available on the NIM model catalog be replaced or supplemented with GLM-5.1 from Z-ai, as GLM-5.1 is a significant post-training update.
Why GLM-5.1 is a Better Fit for NIM
GLM-5.1 is built on the exact same architecture as GLM-5 (744B total / 40B active MoE parameters), but has been heavily fine-tuned for agentic coding workflows. The key improvements include:
What Changed in 5.1
  1. Better Agentic Task Performance
    • Improved instruction following — stays locked onto the main objective without deviating
    • Self-debugging loops — runs linters, catches errors, and iterates until the task is genuinely complete
    • Better planning — absorbs full context before making changes instead of rushing to generate code
    • More reliable interleaved thinking for long-horizon tasks
  2. Adaptive Reasoning Efficiency
    • GLM-5 was a heavy over-reasoner, applying deep chain-of-thought even on trivial tasks
    • GLM-5.1 adaptively scales reasoning — simple tasks get fast responses, complex tasks get full thinking
    • The net effect is noticeably snappier in day-to-day use
Spec Comparison
GLM-5.1 keeps all the same core specs as GLM-5:
  • 744B total / 40B active parameters (MoE)
  • 204,800 token context window
  • 131,072 max output tokens
  • Reasoning mode, function calling, structured output, streaming
Agentic Leaderboard Ranking
  • GLM-5: No specific agentic ranking
  • GLM-5.1: 2nd overall on agentic tasks leaderboard
Use Case
For developers running agentic coding workflows inside tools like Claude Code, Cline, or Open Claw, GLM-5.1 is a clear upgrade. GLM-5 had a known tendency to overdo things and get stuck on multi-step tasks — GLM-5.1 fixes this.
Request
Could the NVIDIA NIM team please consider updating the catalog to offer GLM-5.1 (or offer both versions as options)? The model ID on Z.ai’s platform is zai/glm-5.1.
Trade-offs to Consider
It’s worth noting that GLM-5.1 shows slight regressions in general chat/math QA and may produce code-biased outputs for plain-text questions. However, for the primary NIM use case of API-driven agentic tasks, GLM-5.1 is demonstrably superior.
Thanks for considering this request!
References:
Tags: glm, model request, upgrade, z-ai, agentic
GLM-5.1 isn’t even publicly available outside of their subscription based platform yet…
Getting the request in before it’s even released.
It is available on huggingface now
Update: I’ve created a new, more urgent thread about this since the deprecation deadline is just days away (April 20, 2026).
I’d encourage anyone affected to follow this thread as well:
URGENT: GLM-5 Deprecation — Replacement z-ai/glm-5.1 Not Available in NIM API
The key issue is that the glm-5 Model by Z-ai | NVIDIA NIM page now shows a deprecation notice pointing users to z-ai/glm-5.1, but that endpoint doesn’t actually exist in the NIM API yet — it returns an error. So there’s no working migration path for current users.
Would really appreciate the NVIDIA NIM team looking into this urgently.
