want to build real time image classification with resnet50 model pretrained with imagenet dataset(1000 classes) using deepstream sdk.
I’m having resnet50 tensorrt optimised engine file.
• Hardware Platform (Jetson / GPU) - jetson nano • DeepStream Version- 6.0 • JetPack Version (valid for Jetson only) - 4.6 • TensorRT Version - 8.2 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) - questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) - I want to build a real time object classification application using deepstream sdk. I’m using resnet50 tensorrt optimised model. I could not find any example. Anyone tried before, any sample application for real time object classification using deepstream sdk?. any leads will be highly appreciated…
no this kind of sample, we usually use classifier model as sgie because it is strict to input source.
you can modify deepstream-test2, remove detector, use classification model as pgie, and add “is-classifier=1” to new pgie configuration file.
I have tried giving the required parameters in configuration file but classifier is not working. I want to know the steps we need to do in osd_callback function.
