I want to retrain a ssd model but encounter the following error
Message type “EvalConfig” has no field named “averge_precision_mode”.
which pointing to the following part in configure file(I followed the document)
eval_config {
validation_period_during_training: 10
averge_precision_mode: SAMPLE
matching_iou_threshold: 0.5
After I delete “averge_precision_mode: SAMPLE”
this error disappeared.
But another error shows.
File “/usr/local/bin/tlt-train-g1”, line 8, in
sys.exit(main())
File “./common/magnet_train.py”, line 33, in main
File “./ssd/scripts/train.py”, line 301, in main
File “./ssd/scripts/train.py”, line 168, in run_experiment
File “./ssd/builders/inputs_builder.py”, line 51, in init
File “./detectnet_v2/dataloader/default_dataloader.py”, line 203, in get_dataset_tensors
File “./detectnet_v2/dataloader/default_dataloader.py”, line 229, in _generate_images_and_ground_truth_labels
File “./modulus/processors/processors.py”, line 227, in call
File “./detectnet_v2/dataloader/utilities.py”, line 60, in call
File “./modulus/processors/tfrecords_iterator.py”, line 143, in process_records
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/array_ops.py”, line 1508, in split
axis=axis, num_split=num_or_size_splits, value=value, name=name)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/gen_array_ops.py”, line 8883, in split
“Split”, split_dim=axis, value=value, num_split=num_split, name=name)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/op_def_library.py”, line 709, in _apply_op_helper
(key, op_type_name, attr_value.i, attr_def.minimum))
ValueError: Attr ‘num_split’ of ‘Split’ Op passed 0 less than minimum 1.
For me tlt looks like a black box.
So anyone can help me how to debug in this situation???
life is sooooo difficult
