Hardware - GPU (A10)
Hardware - CPU
Operating System
Riva Version: 2.18.0
TLT Version (if relevant) - No
How to reproduce the issue ?
Command and logs below:
root@xfusion-server:/opt/riva# ./clients/riva_asr_client --riva_uri=0.0.0.0:50051 --audio_file=/opt/riva/wav/‘RC Audio Test 2(1).wav’ --model_name=whisper-large-v3-multi-asr-offline-asr-bls-ensemble --language_code=ar-AR --output_filename ‘riva-output.txt’
I0120 07:00:01.267732 252 grpc.h:94] Using Insecure Server Credentials
Loading eval dataset…
filename: /opt/riva/wav/RC Audio Test 2(1).wav
Done loading 1 files
File: /opt/riva/wav/RC Audio Test 2(1).wav
Final transcripts:
0 : السلام عليكم اشتركوا في القناة لا تتردد تواصل معنا لا لا جزاكم الله خير شكرا الله يشفيك ويحفظك حنا معك
Word Start (ms) End (ms) Confidence
Audio processed: 65.6428 sec.
Done processing 1 responses
Latencies (ms):
Median 90th 95th 99th Avg
1201.6 1201.6 1201.6 1201.6 1201.6
Run time: 1.2154 sec.
Total audio processed: 65.643 sec.
Throughput: 54.009 RTFX
Final transcripts written to riva-output.txt
I try to run on a rather long audio file but it returns only final (part) of the audio but I am in need to get the whole. Am I making a mistake here or is there something I am missing? Need help.
