Robot Seem to Teleport around on rviz2
Hi, I am running a simulation on Isaac Sim, using nav2 goal to send the robot to its goal location. However, while going to its goal location the robot doesnt seem to properly follow the path shown on rviz2. This causes the robot to hit the obstacle due to the lag between Isaac Sim and RVIZ2. How may I solve this problem?
Below is my params file for the robot:
amcl:
ros__parameters:
use_sim_time: True
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: “base_link”
beam_skip_distance: 0.5
beam_skip_error_threshold: 0.9
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: “map”
lambda_short: 0.1
laser_likelihood_max_dist: 2.0
laser_max_range: 100.0
laser_min_range: -1.0
laser_model_type: “likelihood_field”
max_beams: 2000
max_particles: 3000
min_particles: 2500
odom_frame_id: “odom”
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 3
robot_model_type: “nav2_amcl::DifferentialMotionModel”
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: scan
map_topic: map
set_initial_pose: true
always_reset_initial_pose: false
first_map_only: false
initial_pose:
x: 3.91796
y: -8.50786
z: 0.0
yaw: 3.14159
amcl_map_client:
ros__parameters:
use_sim_time: True
amcl_rclcpp_node:
ros__parameters:
use_sim_time: True
bt_navigator:
ros__parameters:
use_sim_time: True
global_frame: map
robot_base_frame: base_link
odom_topic: odom
bt_loop_duration: 20
default_server_timeout: 40
# ‘default_nav_through_poses_bt_xml’ and ‘default_nav_to_pose_bt_xml’ are use defaults:
# nav2_bt_navigator/navigate_to_pose_w_replanning_and_recovery.xml
# nav2_bt_navigator/navigate_through_poses_w_replanning_and_recovery.xml
# They can be set here or via a RewrittenYaml remap from a parent launch file to Nav2.
plugin_lib_names:
- nav2_compute_path_to_pose_action_bt_node
- nav2_compute_path_through_poses_action_bt_node
- nav2_smooth_path_action_bt_node
- nav2_follow_path_action_bt_node
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_back_up_action_bt_node
- nav2_drive_on_heading_bt_node
- nav2_clear_costmap_service_bt_node
- nav2_is_stuck_condition_bt_node
- nav2_goal_reached_condition_bt_node
- nav2_goal_updated_condition_bt_node
- nav2_globally_updated_goal_condition_bt_node
- nav2_is_path_valid_condition_bt_node
- nav2_initial_pose_received_condition_bt_node
- nav2_reinitialize_global_localization_service_bt_node
- nav2_rate_controller_bt_node
- nav2_distance_controller_bt_node
- nav2_speed_controller_bt_node
- nav2_truncate_path_action_bt_node
- nav2_truncate_path_local_action_bt_node
- nav2_goal_updater_node_bt_node
- nav2_recovery_node_bt_node
- nav2_pipeline_sequence_bt_node
- nav2_round_robin_node_bt_node
- nav2_transform_available_condition_bt_node
- nav2_time_expired_condition_bt_node
- nav2_path_expiring_timer_condition
- nav2_distance_traveled_condition_bt_node
- nav2_single_trigger_bt_node
- nav2_is_battery_low_condition_bt_node
- nav2_navigate_through_poses_action_bt_node
- nav2_navigate_to_pose_action_bt_node
- nav2_remove_passed_goals_action_bt_node
- nav2_planner_selector_bt_node
- nav2_controller_selector_bt_node
- nav2_goal_checker_selector_bt_node
- nav2_controller_cancel_bt_node
- nav2_path_longer_on_approach_bt_node
- nav2_wait_cancel_bt_node
- nav2_spin_cancel_bt_node
- nav2_back_up_cancel_bt_node
- nav2_drive_on_heading_cancel_bt_node
bt_navigator_rclcpp_node:
ros__parameters:
use_sim_time: True
velocity_smoother:
ros__parameters:
smoothing_frequency: 20.0
scale_velocities: false
feedback: “OPEN_LOOP”
max_velocity: [1.5, 1.0, 3.0]
min_velocity: [-1.5, -1.0, -3.0]
# deadband_velocity: [0.0, 0.0, 0.0]
velocity_timeout: 1.0
# max_accel: [1.0, 0.0, 1.25]
# max_decel: [-1.0, 0.0, -1.25]
odom_topic: “odom”
odom_duration: 0.1
controller_server:
ros__parameters:
use_sim_time: True
controller_frequency: 5.0
min_x_velocity_threshold: 0.001
min_y_velocity_threshold: 0.001
min_theta_velocity_threshold: 0.001
failure_tolerance: 0.3
progress_checker_plugin: “progress_checker”
goal_checker_plugin: [“stopped_goal_checker”]
controller_plugins: [“FollowPath”]
# Progress checker parameters
progress_checker:
  plugin: "nav2_controller::SimpleProgressChecker"
  required_movement_radius: 0.7
  movement_time_allowance: 10.0
# Goal checker parameters
stopped_goal_checker:
  plugin: "nav2_controller::StoppedGoalChecker"
  xy_goal_tolerance: 0.25
  yaw_goal_tolerance: 0.25
  stateful: True
# DWB parameters
FollowPath:
  plugin: "dwb_core::DWBLocalPlanner"
  debug_trajectory_details: True
  min_vel_x: 0.0
  min_vel_y: 0.0
  max_vel_x: 1.4
  max_vel_y: 0.7
  max_vel_theta: 3.0
  min_speed_xy: 0.0
  max_speed_xy: 1.8
  min_speed_theta: 0.0
  acc_lim_x: 2.5
  acc_lim_y: 0.0
  acc_lim_theta: 2.3
  decel_lim_x: -2.5
  decel_lim_y: 0.0
  decel_lim_theta: -3.2
  vx_samples: 40
  vy_samples: 5
  vtheta_samples: 40
  sim_time: 1.7
  linear_granularity: 0.025
  angular_granularity: 0.025
  transform_tolerance: 0.1
  trans_stopped_velocity: 0.25
  short_circuit_trajectory_evaluation: True
  stateful: True
  critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
  BaseObstacle.scale: 17.0
  PathAlign.scale: 50.0
  PathAlign.forward_point_distance: 0.01
  GoalAlign.scale: 24.0
  GoalAlign.forward_point_distance: 0.1
  PathDist.scale: 32.0
  GoalDist.scale: 24.0
  RotateToGoal.scale: 32.0
  RotateToGoal.slowing_factor: 5.0
  RotateToGoal.lookahead_time: -1.0
controller_server_rclcpp_node:
ros__parameters:
use_sim_time: True
local_costmap:
local_costmap:
ros__parameters:
update_frequency: 10.0
publish_frequency: 10.0
footprint_padding: 0.33
global_frame: odom
use_sim_time: True
rolling_window: True
width: 8
height: 7
resolution: 0.05
#footprint: “[ [0.14, 0.25], [0.14, -0.25], [-0.607, -0.25], [-0.607, 0.25] ]”
footprint: “[ [0.14, 0.25], [0.14, -0.35], [-0.607, -0.35], [-0.607, 0.25] ]”
  plugins: ["hesai_voxel_layer", "front_rplidar_obstacle_layer", "back_rplidar_obstacle_layer", "inflation_layer"]
  # plugins: ["hesai_voxel_layer", "inflation_layer"]
  inflation_layer:
    plugin: "nav2_costmap_2d::InflationLayer"
    enabled: True
    cost_scaling_factor: 0.3
    inflation_radius: 0.41
  hesai_voxel_layer:
    plugin: "nav2_costmap_2d::VoxelLayer"
    enabled: True
    footprint_clearing_enabled: true
    max_obstacle_height: 2.0
    publish_voxel_map: False
    origin_z: 0.0
    z_voxels: 16
    z_resolution: 0.2
    unknown_threshold: 15
    observation_sources: pointcloud
    pointcloud:  # no frame set, uses frame from message
      topic: /carter1/front_3d_lidar/point_cloud
      min_obstacle_height: 0.1
      obstacle_max_range: 10.0
      obstacle_min_range: 0.0
      raytrace_max_range: 10.0
      raytrace_min_range: 0.0
      clearing: True
      marking: True
      data_type: "PointCloud2"
  front_rplidar_obstacle_layer:
    plugin: "nav2_costmap_2d::ObstacleLayer"
    enabled: True
    observation_sources: scan
    scan:
      topic: /carter1/front_2d_lidar/scan
      clearing: True
      marking: True
      data_type: "LaserScan"
  back_rplidar_obstacle_layer:
    enabled: True
    scan:
      topic: /carter1/back_2d_lidar/scan
      clearing: True
      marking: True
local_costmap_client:
ros__parameters:
use_sim_time: True
local_costmap_rclcpp_node:
ros__parameters:
use_sim_time: True
global_costmap:
global_costmap:
ros__parameters:
global_frame: map
use_sim_time: True
  resolution: 0.05
  plugins: ["static_layer", "obstacle_layer", "inflation_layer"]
  obstacle_layer:
    enabled: True
    scan:
      topic: /carter1/scan
      clearing: True
      marking: True
  static_layer:
    plugin: "nav2_costmap_2d::StaticLayer"
    map_subscribe_transient_local: True
  inflation_layer:
    inflation_radius: 0.45
  always_send_full_costmap: True
global_costmap_client:
ros__parameters:
use_sim_time: True
global_costmap_rclcpp_node:
ros__parameters:
use_sim_time: True
map_server:
ros__parameters:
use_sim_time: True
yaml_filename: “carter_Simualtion_navigation.yaml”
map_saver:
ros__parameters:
use_sim_time: True
save_map_timeout: 5000
free_thresh_default: 0.25
occupied_thresh_default: 0.65
planner_server:
ros__parameters:
expected_planner_frequency: 100.0
use_sim_time: True
planner_plugins: [“GridBased”]
GridBased:
plugin: “nav2_navfn_planner/NavfnPlanner”
tolerance: 0.4
use_astar: false
allow_unknown: true
planner_server_rclcpp_node:
ros__parameters:
use_sim_time: True
smoother_server:
ros__parameters:
use_sim_time: True
smoother_plugins: [“simple_smoother”]
simple_smoother:
plugin: “nav2_smoother::SimpleSmoother”
tolerance: 1.0e-10
max_its: 1000
do_refinement: True
behavior_server:
ros__parameters:
costmap_topic: local_costmap/costmap_raw
footprint_topic: local_costmap/published_footprint
cycle_frequency: 5.0
behavior_plugins: [“spin”, “backup”, “drive_on_heading”, “wait”]
#behavior_plugins: [“backup”, “drive_on_heading”, “wait”]
spin:
plugin: “nav2_behaviors/Spin”
backup:
plugin: “nav2_behaviors/BackUp”
drive_on_heading:
plugin: “nav2_behaviors/DriveOnHeading”
wait:
plugin: “nav2_behaviors/Wait”
global_frame: odom
transform_tolerance: 0.2
use_sim_time: true
simulate_ahead_time: 0.1
max_rotational_vel: 1.0
min_rotational_vel: 0.4
rotational_acc_lim: 3.2
robot_state_publisher:
ros__parameters:
use_sim_time: True
waypoint_follower:
ros__parameters:
use_sim_time: True
loop_rate: 20
stop_on_failure: false
waypoint_task_executor_plugin: “wait_at_waypoint”
wait_at_waypoint:
plugin: “nav2_waypoint_follower::WaitAtWaypoint”
enabled: True
waypoint_pause_duration: 10
Hi @ashlynsamuelabey have you resolved this issue? There could be multiple causes:
  1. Ensure RViz2 uses Isaac Sim’s clock. You can check if use_sim_time of rviz node is true or not by running ros2 param get /rviz use_sim_time
  2. Try to disable Publish Full Scan in the sensor nodes in nova_carter, which will help save some GPU load
  3. Check your TF between map and base_link and see if it aligns with Isaac Sim ground truth.
