I am trying to get this Telit WiFi 6 and BT 5.2 module working with Jetson Orin Nano using Jetpack 6. This chipset uses the RTL8852BE and requires a corresponding driver.
I’ve tried building the kernel from source and enabling the realtek drivers by adding these to the defconfig
CONFIG_NET_VENDOR_REALTEK=y
CONFIG_WLAN_VENDOR_REALTEK=y
CONFIG_RTL_CARDS=y
CONFIG_BT_RTL=y
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_BT_HCIUART_RTL=y
CONFIG_USB_RTL8153_ECM=y
CONFIG_RTW89=y
CONFIG_RTW89_8852AE=y
CONFIG_RTW89_CORE=y
CONFIG_RTW89_PCI=y
CONFIG_RTL8XXXU=y
CONFIG_REALTEK_PHY=y
CONFIG_USB_RTL8150=y
CONFIG_USB_RTL8152=y
This is what lspci shows me
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
Subsystem: Realtek Semiconductor Co., Ltd. Device b852
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 255
Region 0: I/O ports at 1000 [disabled] [size=256]
Region 2: Memory at 20a8000000 (64-bit, non-prefetchable) [disabled] [size=1M]
Capabilities: <access denied>
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 189
IOMMU group: 34
Region 0: I/O ports at 300000 [size=256]
Region 2: Memory at 3528004000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 3528000000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8168
Kernel modules: r8168
and dmesg shows the ethernet driver is loaded
[ 0.255017] usbcore: registered new interface driver rtl8150
So next I tried installing from source on the device
git clone https://github.com/lwfinger/rtw89.git
cd rtw89
make KSRC=/usr/src/linux-headers-5.15.136-tegra-ubuntu22.04_aarch64/3rdparty/canonical/linux-jammy/kernel-source/
However after doing so and rebooting, system commands like dmesg no longer function.
Can someone advise on how to properly support this chipset? My ideal solution would be to include this driver in my source build, since I am already building from source for my project.
