Hi
Can anyone provide a comparison chart between Jetson products on the number of RTSP streams it can handle without additional hardware addons.
Hi
This is not an answer, but you may further tell about your case such as receiving or sending RTSP streams, what encoding or decoding, resolution and framerate, processing if any, and how many streams for your case, for better advice.
I may not advise further, but you may try DeepStream, benchmark your case and share here.
We have demonstration for 30 video file sources in DeepStream SDK. If the network is good and stable, you should be able to reach the same performance in RTSP sources.
Thank you very much that helps.
