Hey guys I tried to compile several cuda samples which most of them failed. I tried several options including installing a bunch of packages and developer packages and using the option
GLPATH=/usr/lib make
System:
Linux ubuntu-workstation 4.4.0-59-generic #80-Ubuntu SMP Fri Jan 6 17:47:47 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
| NVIDIA-SMI 375.26 Driver Version: 375.26 |
| 0 GeForce GTX 460 Off | 0000:01:00.0 N/A | N/A |
| 40% 49C P0 N/A / N/A | 377MiB / 958MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Sun_Sep__4_22:14:01_CDT_2016
Cuda compilation tools, release 8.0, V8.0.44
System was installed with both binary CUDA and binary driver from the NVIDIA website. No package system was used.
One example: When i try to compile “nbody” I get the following error.
make
"/usr/local/cuda-8.0"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_60,code=compute_60 -o nbody bodysystemcuda.o nbody.o render_particles.o -L/usr/lib/"nvidia-367" -lGL -lGLU -lX11 -lglut
nvcc warning : The 'compute_20', 'sm_20', and 'sm_21' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
/usr/bin/ld: cannot find -lGL
collect2: error: ld returned 1 exit status
Makefile:275: recipe for target 'nbody' failed
make: *** [nbody] Error 1
The make output for all samples can be found here:
https://paste.ubuntu.com/23795737/
Output before i installed the packages mentioned in the “WARNING” messages.
https://paste.ubuntu.com/23795770/
I hope that by having a look at the logs you may see something. If so please give me a hint in how to progress further. I am stuck at the moment. If you need any additional information, please ask i will provide it.
Thank You very much,
Hir I Mogul
