I want to know if it is possible to run multiple models at one time on xavier.
For example, I have two trained models: t1.pb and t2.pb.I want to load these two models at the same time in a run: t1.pb running with GPU and t2.pb running with XLA, both of which are parallel.
If you have relevant information in this regard, can you tell me, thank you.
I seem to be able to specify the device that the model runs on( with tf.device(‘/gpu:0’) ), but what should I do to make the two models run simultaneously, instead of t1.pb running on GPU and then t2.pb running on XLA serially?
device infomation:
/job:localhost/replica:0/task:0/device:XLA_CPU:0 → device: XLA_CPU device
/job:localhost/replica:0/task:0/device:XLA_GPU:0 → device: XLA_GPU device
/job:localhost/replica:0/task:0/device:GPU:0 → device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2
and, how to run with xla_gpu?
with tf.device('device:XLA_GPU:0'):
doesn’t work
