Hi All,
I do have one custom image classification CNN model in python , How do I run this in target ? Is there is any examples or tutorial to follow, I am not sure how deep streamer library convert python to C or C++ and other details.
Will be helpful if I get a example to run a custom model prepared in python run on target
Which framework do you use? PyTorch or TensorFlow?
Both frameworks can be installed on the Jetson. Please find the information below:
You can deploy it on the target in the same way as the desktop after installing the package.
https://docs.nvidia.com/deeplearning/frameworks/install-pytorch-jetson-platform/index.html
https://docs.nvidia.com/deeplearning/frameworks/install-tf-jetson-platform/index.html
