• Hardware Platform (Jetson / GPU) : V100
• DeepStream Version : 6.0
• JetPack Version (valid for Jetson only) : docker container in NGC (devel tag)
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) : 418.67
• Issue Type( questions, new requirements, bugs) bugs
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) use ds with yolov3
I get this nvdec error when i run my yolov3 in ds 6.0 :
root@a176e9810bd2:~/top# deepstream-cdmsmith-analytics -c main_config.txt
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
0:00:03.128145540 216 0x55fdb616b660 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/root/top/models/yolov3/model_b1_gpu0_fp32_cuda114.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT data 3x608x608
1 OUTPUT kFLOAT yolo_83 255x19x19
2 OUTPUT kFLOAT yolo_95 255x38x38
3 OUTPUT kFLOAT yolo_107 255x76x76
0:00:03.128283984 216 0x55fdb616b660 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /root/top/models/yolov3/model_b1_gpu0_fp32_cuda114.engine
0:00:03.136729688 216 0x55fdb616b660 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/root/top/models/yolov3/config_infer_primary_yolov3.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:181>: Pipeline ready
terminate called after throwing an instance of ‘NVDECException’
what(): cuvidv4l2_handle_video_sequence_cb : No supported output format found at src/cuvidv4l2_nvdec.cpp:399
Aborted (core dumped)
