Running .engine file outside deepstream SDK
I’ve used the TLT to train, prune and export a model, and converted it to a .engine file on the Jetson Xavier platform. But I want to use the .engine without the deepstream SDK or include the deepstread SDK into my python code (or c++ if that is required)
I have previously used Tensorflow with their object detection API and the NVIDIA tf-trt API to optimize the models for my embedded platforms.
Is this possible?
Best regards
Kevin
Hi kevingrooters,
Take Faster_rcnn as an example, how to run inference using the trained FasterRCNN models from TLT is provided on github: GitHub - NVIDIA-AI-IOT/deepstream_4.x_apps: deepstream 4.x samples to deploy TLT training models . The pre-processing and post processing code are already exposed in C++ inside nvdsinfer_customparser_frcnn_uff folder.
Furthermore, to config TRT engine directly instead of etlt model, you can refer to the 4th comment of https://devtalk.nvidia.com/default/topic/1063940/transfer-learning-toolkit/transfert-learning-toolkit-gt-export-model-/
