Running Kokoro TTS on NVIDIA DGX Spark (ARM64/GB10)
I successfully got Kokoro TTS running on the DGX Spark with full GPU acceleration. Here’s a step-by-step guide for anyone else looking to deploy this. Also Japanese voices ready (which was the biggest painpoint).
What is Kokoro TTS?
Kokoro is a fast, multilingual text-to-speech model (82M parameters) that supports multiple languages and 67 voice packs. Critically for ARM64 users: it includes working Japanese TTS with proper phonemization - something that’s notoriously difficult to get working on ARM architecture due to MeCab/Unidic dependencies.
Why This Guide?
Most TTS solutions struggle with:
  • Japanese language support on ARM64 - MeCab and Unidic are tricky to compile/configure
  • GPU acceleration on GB10 - CUDA 12.1 compatibility warnings
  • Docker build failures - The original Dockerfile has ordering issues
This guide solves all three.
Prerequisites
  • NVIDIA DGX Spark with DGX OS
  • Docker with GPU support enabled
  • ~18GB disk space for the image
Step-by-Step Setup
1. Clone the Repository
bash
cd ~
git clone https://github.com/remsky/Kokoro-FastAPI.git
cd Kokoro-FastAPI
2. Update the Dockerfile for ARM64
The original GPU Dockerfile needs modification to work properly on ARM64. The key issue is that project files need to be copied BEFORE running uv sync.
Edit the Dockerfile:
bash
cd ~/Kokoro-FastAPI/docker/gpu
nano Dockerfile
Replace with this corrected version:
dockerfile
# Base image
FROM nvidia/cuda:12.2.0-base-ubuntu22.04
# 1. Install system dependencies
RUN apt-get update -y &&  \
    apt-get install -y \
    python3.10 python3.10-dev python3-venv \
    espeak-ng espeak-ng-data git libsndfile1 curl ffmpeg g++ build-essential cmake && \
    apt-get clean && rm -rf /var/lib/apt/lists/*
# 2. Setup folders and user
RUN mkdir -p /app && \
    useradd -m -u 1001 appuser && \
    chown -R appuser:appuser /app
# 3. Install uv globally
RUN curl -LsSf https://astral.sh/uv/install.sh | sh && \
    mv /root/.local/bin/uv /usr/local/bin/
WORKDIR /app
USER appuser
# 4. Copy ALL project files first (needed for uv sync to build the package)
COPY --chown=appuser:appuser pyproject.toml ./pyproject.toml
COPY --chown=appuser:appuser api ./api
COPY --chown=appuser:appuser web ./web
COPY --chown=appuser:appuser docker/scripts/ ./
# 5. Install CUDA-enabled PyTorch and dependencies
RUN uv venv --python 3.10 && \
    uv pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu121 && \
    uv sync --extra gpu --no-cache && \
    uv pip install unidic-lite && \
    mkdir -p /app/.venv/lib/python3.10/site-packages/unidic && \
    ln -s /app/.venv/lib/python3.10/site-packages/unidic_lite/dicdir /app/.venv/lib/python3.10/site-packages/unidic/dicdir
RUN chmod +x ./entrypoint.sh
# 6. Set environment variables
ENV PATH="/app/.venv/bin:$PATH" \
    PYTHONUNBUFFERED=1 \
    PYTHONPATH=/app:/app/api \
    USE_GPU=true \
    DEVICE="cuda" \
    MECABRC=/app/.venv/lib/python3.10/site-packages/unidic/dicdir/mecabrc \
    PHONEMIZER_ESPEAK_PATH=/usr/bin \
    PHONEMIZER_ESPEAK_DATA=/usr/share/espeak-ng-data
# 7. Download model
RUN mkdir -p api/src/models/v1_0 && \
    python ./download_model.py --output api/src/models/v1_0
CMD ["./entrypoint.sh"]
Key change from original: Step 4 now copies all project files BEFORE running uv sync (which needs them to build the package).
3. Build the Docker Image
bash
cd ~/Kokoro-FastAPI
docker build --platform linux/arm64 -t kokoro-tts-arm64 -f docker/gpu/Dockerfile .
Build time: ~5-10 minutes depending on network speed.
4. Run the Container
The service internally uses port 8880 (not 8000). Clean up any existing container and start fresh:
bash
docker stop kokoro-tts || true && docker rm kokoro-tts || true
docker run -d \
  --name kokoro-tts \
  --gpus all \
  -p 7860:8880 \
  -e USE_GPU=true \
  -e DEVICE=cuda \
  kokoro-tts-arm64
5. Verify It’s Running
Check the logs:
bash
docker logs -f kokoro-tts
You should see:
Model warmed up on cuda: kokoro_v1
CUDA: True
67 voice packs loaded
Beta Web Player: http://0.0.0.0:8880/web/
Accessing the Service
  • Web Interface: http://localhost:7860/web/
  • API Documentation: http://localhost:7860/docs
  • API Endpoint: http://localhost:7860
Replace localhost with your DGX Spark’s IP address for remote access.
Notes & Observations
CUDA Compatibility Warning
You’ll see this warning in the logs:
Found GPU0 NVIDIA GB10 which is of cuda capability 12.1.
Minimum and Maximum cuda capability supported by this version of PyTorch is (8.0) - (12.0)
This is harmless - PyTorch gracefully handles the GB10’s SM 12.1 architecture despite the warning. The model loads and runs perfectly.
Performance
  • Model warmup: ~4 seconds
  • Running on CUDA with full GPU acceleration
  • 67 voice packs available out of the box
  • Supports multiple languages including English, Japanese, German, and more
Managing the Container
bash
# View logs
# Stop and remove
docker stop kokoro-tts && docker rm kokoro-tts
# Restart
docker restart kokoro-tts
# Rebuild after Dockerfile changes
cd ~/Kokoro-FastAPI
Troubleshooting
Build fails with “api/src does not exist or is not a directory”:
  • The original Dockerfile copies files in the wrong order
  • Use the corrected Dockerfile above which copies project files BEFORE uv sync
Port 7860 already in use:
  • Change the external port mapping: -p YOUR_PORT:8880
GPU not detected:
  • Verify Docker GPU support: docker run --rm --gpus all nvidia/cuda:12.2.0-base-ubuntu22.04 nvidia-smi
Container exits immediately:
  • Check logs: docker logs kokoro-tts
  • Ensure all required files are present in the repo
Use Cases
This setup is great for:
  • Local voice assistant pipelines
  • Multilingual TTS applications
  • Japanese language learning tools
  • Real-time voice synthesis
  • Alternative to cloud TTS APIs
  • Integration with robotics projects (teleoperation feedback, etc.)
Complete Quick Reference
bash
# Clone and setup
cd ~
cd Kokoro-FastAPI/docker/gpu
nano Dockerfile  # Apply the corrected Dockerfile above
# Build
cd ~/Kokoro-FastAPI
# Run
docker run -d \
  --name kokoro-tts \
  --gpus all \
  -p 7860:8880 \
  -e USE_GPU=true \
  -e DEVICE=cuda \
  kokoro-tts-arm64
# Verify
Credits
Hope this helps other DGX Spark users! The key fix is ensuring project files are copied before the build step tries to install the package.
Hey, maintainer on Kokoro-FastAPI here. Glad it’s running on the Spark, and thanks for using the project and writing it up!
One note I wanted to mention/ask: the published image should already be multi-arch, including linux/arm64 with cu129 wheels, and has been since Dec 2025; with full Japanese unidic, so no build should be needed with (it was definitely a challenge getting it to play nicely on arm64)
docker run --gpus all -p 8880:8880 ghcr.io/remsky/kokoro-fastapi-gpu:latest
Do you recall the version you were building from? The existing repo Dockerfile.optimized creates `api/src` in the first RUN step, so `uv sync` should go through before the copy; the base has been `nvcr.io/nvidia/cuda:12.9.1` on ubuntu 24.04 for a little while prior to your post as well.
Just want to understand to see if I can resolve anything at the source. If it failed on a clean clone let me know any details if you can, don’t have a GB10 to test on.
