Running tao toolkit in google colab
Some weeks ago I was running without any problems in google colab the notebooks for training: yolo_v4, yolo_v4tiny, yolo_v3 and ssd (TAO Toolkit | NVIDIA NGC). Now, I am running the same notebooks from the same github repository without making any change and tao setup is not performed properly. Now I cannot run any model. When I run “https://github.com/NVIDIA-AI-IOT/nvidia-tao/blob/main/tensorflow/setup_env.sh” I got next messages
Successfully built addict future mpi4py posix-ipc prettytable pycocotools-fix pycuda recordclass retrying seaborn semver simplejson tabulate DLLogger promise pytools fire pathtools termcolor
Installing collected packages: zipp, typing-extensions, six, ipython-genutils, decorator, traitlets, setuptools, pyrsistent, importlib-metadata, attrs, wcwidth, tornado, pyzmq, python-dateutil, pyparsing, pycparser, ptyprocess, parso, nest-asyncio, jupyter-core, jsonschema, entrypoints, webencodings, pygments, prompt-toolkit, pickleshare, pexpect, packaging, nbformat, MarkupSafe, jupyter-client, jedi, cffi, backcall, async-generator, testpath, pandocfilters, nbclient, mistune, jupyterlab-pygments, jinja2, ipython, defusedxml, dataclasses, bleach, argon2-cffi-bindings, terminado, Send2Trash, prometheus-client, numpy, nbconvert, ipykernel, argon2-cffi, urllib3, smmap, protobuf, notebook, jmespath, h5py, docutils, widgetsnbextension, termcolor, scipy, qtpy, PyYAML, platformdirs, Pillow, orderedmultidict, onnx, kiwisolver, keras-preprocessing, keras-applications, jupyterlab-widgets, idna, gitdb, cycler, chardet, certifi, botocore, uritemplate, tifffile, threadpoolctl, shortuuid, setproctitle, sentry-sdk, s3transfer, requests, qtconsole, PyWavelets, pytz, pytools, pyjwt, psutil, promise, pathtools, pathlib2, onnxconverter-common, networkx, matplotlib, mako, llvmlite, keras, jupyter-console, joblib, ipywidgets, imageio, GitPython, future, furl, flatbuffers, fire, docker-pycreds, cython, Click, appdirs, xmltodict, wandb, uplink, uff, tqdm, toposort, tf2onnx, tabulate, simplejson, shapely, semver, seaborn, scikit-learn, scikit-image, retrying, requests-toolbelt, recordclass, pycuda, pycocotools-fix, pyarrow, prettytable, posix-ipc, pandas, opencv-python, onnxruntime, onnx-graphsurgeon, nvidia-ml-py, numba, mpi4py, keras2onnx, keras-metrics, jupyter, grpcio, graphsurgeon, DLLogger, cryptography, clearml, boto3, argparse, argcomplete, addict
ERROR: pip’s dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
nvidia-tao 4.0.0 requires idna==2.10, but you have idna 2.7 which is incompatible.
nvidia-tao 4.0.0 requires six==1.15.0, but you have six 1.13.0 which is incompatible.
nvidia-tao 4.0.0 requires tabulate==0.8.7, but you have tabulate 0.7.5 which is incompatible.
nvidia-tao 4.0.0 requires urllib3>=1.26.5, but you have urllib3 1.24.3 which is incompatible.
google-colab 1.0.0 requires ipykernel~=4.6.0, but you have ipykernel 5.5.6 which is incompatible.
google-colab 1.0.0 requires ipython~=5.5.0, but you have ipython 7.16.3 which is incompatible.
google-colab 1.0.0 requires notebook~=5.2.0, but you have notebook 6.4.10 which is incompatible.
google-colab 1.0.0 requires pandas~=0.24.0, but you have pandas 0.25.3 which is incompatible.
google-colab 1.0.0 requires requests~=2.21.0, but you have requests 2.20.1 which is incompatible.
google-colab 1.0.0 requires six~=1.12.0, but you have six 1.13.0 which is incompatible.
google-colab 1.0.0 requires tornado~=4.5.0, but you have tornado 6.1 which is incompatible.
Then, when I try to run any command of tao like !tao yolo_v4 -h I got next error:
Using TensorFlow backend.
File “/usr/local/bin/yolo_v4”, line 5, in
from iva.yolo_v4.entrypoint.yolo_v4 import main
File “/usr/local/lib/python3.6/dist-packages/iva/init.py”, line 10, in
import third_party.keras.mixed_precision as MP
File “/usr/local/lib/python3.6/dist-packages/third_party/keras/mixed_precision.py”, line 11, in
import keras
File “/usr/local/lib/python3.6/dist-packages/keras/init.py”, line 3, in
from . import utils
File “/usr/local/lib/python3.6/dist-packages/keras/utils/init.py”, line 6, in
from . import conv_utils
File “/usr/local/lib/python3.6/dist-packages/keras/utils/conv_utils.py”, line 9, in
from … import backend as K
File “/usr/local/lib/python3.6/dist-packages/keras/backend/init.py”, line 89, in
from .tensorflow_backend import *
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 5, in
import tensorflow as tf
ModuleNotFoundError: No module named ‘tensorflow’
What could be the problem? maybe recent updates of google colab?
General information:
• Hardware (T4)
• Google Colab (Yolo_v4/Yolo_v4tiny/Yolo_v3/etc). I want to emphasize that I am running in google colab and not in a docker container. In google colab we cannot run the containers. I am running in colab because I do not have a local machine with GPU
• How to reproduce the issue ? You could reproduce it by only running the notebooks from the oficial github in google colab:
There is not update recently. Could you save the .ipynb and upload here?
Sure, I share the notebook:
yolo_v4.ipynb (34.1 KB)
It is the same of the repository:
Do you have any log when you run this notebook? If yes, please save it and share with us.
I’m having the same error as this guy. When I dug into the problem and checked it, I found that there was an error “python3.6 -m pip install https://developer.download.nvidia.com/compute/redist/nvidia-tensorflow/nvidia_tensorflow-1.15.4+nv20.10-cp36-cp36m-linux_x86_64.whl” in the “setup_env.sh”
The error code that occurred when executing the code is as follows.
ERROR: Could not find a version that satisfies the requirement nvidia-cuda-cupti==11.1.69 (from nvidia-tensorflow) (from versions: 0.0.1.dev4, 0.0.1.dev5)
ERROR: No matching distribution found for nvidia-cuda-cupti==11.1.69
How can I solve it?
Can you save the .ipynb file and share with us?
I didn’t save any files separately, but after going through that process, I tried running the error code that occured again.
  1. [Set up env variables]
  2. [Prepare dataset and pre-trained model]
    1.1 [Download the dataset](
    1.2 [Verify the downloaded dataset]
    1.3 [Download pretrained model]
  3. [Setup GPU environment]
    2.1 [Connect to GPU Instance]
    2.2 [Mounting Google drive]
    2.3 [Setup Python environment]
    2.4 [Reset env variables]
and I tried "!pip install tensorflow==1.15.4 before the method presented above, but the process also encountered an error while executing “!tao yolo_v4_tiny dataset_convert -d $SPECS_DIR/yolo_v4_tiny_tfrecords_kitti_train.txt \ -o $DATA_DIR/training/tfrecords/train” code.
Can you click as below and then save the log to an .ipynb file?
yolo_v4_tiny.ipynb (615.0 KB)
Thanks, I can also reproduce the error. Will check further internally.
Getting the exact same error messages as @img1518
I ma also getting the same error. What should we do to resolve this?
It is a sudden issue since last week. We are still working on that. Will update to you if any. Sorry for inconvenient.
Please modify setup_env.sh to below.
#!/bin/sh
# Install Python 3.6 as the default version
sudo add-apt-repository ppa:deadsnakes/ppa -y
sudo apt-get update
sudo apt-get install python3.6 -y
apt install python3-pip -y
apt-get install python3.6-distutils
apt-get install python3.6-dev
# Set Python 3.6 as the default version
rm /usr/bin/python
ln -sf /usr/bin/python3.6 /usr/bin/python3
ln -sf /usr/bin/python3.6 /usr/local/bin/python
python3.6 -m pip install --upgrade pip
python3.6 -m pip install google-colab
python3.6 -m pip install nvidia-pyindex
# Install Tensorflow
python3.6 -m pip install https://developer.download.nvidia.com/compute/redist/nvidia-horovod/nvidia_horovod-0.20.0+nv20.10-cp36-cp36m-linux_x86_64.whl
python3.6 -m pip install --extra-index-url https://developer.download.nvidia.com/compute/redist nvidia-tensorflow==1.15.4+nv20.10
# Install Cmake
cd /tmp
wget https://github.com/Kitware/CMake/releases/download/v3.14.4/cmake-3.14.4-Linux-x86_64.sh
chmod +x cmake-3.14.4-Linux-x86_64.sh
./cmake-3.14.4-Linux-x86_64.sh --prefix=/usr/local --exclude-subdir --skip-license
rm ./cmake-3.14.4-Linux-x86_64.sh
# Install dependencies
python3.6 -m pip install --extra-index-url https://developer.download.nvidia.com/compute/redist nvidia-eff==0.5.3
python3.6 -m pip install nvidia-tao==4.0.0
python3.6 -m pip install --ignore-installed PyYAML -r /content/drive/MyDrive/nvidia-tao/tensorflow/requirements-pip.txt -f https://download.pytorch.org/whl/torch_stable.html --extra-index-url https://developer.download.nvidia.com/compute/redist
# Install code related wheels
python3.6 -m pip install nvidia-tao-tf1==4.0.0.657.dev0
