Some .run installer driver wasn’t cleanly uninstalled. Please remove those files:
sudo rm /usr/lib/libnvidia-ml.so* /usr/lib64/libnvidia-ml.so*
and try reinstalling the correct libs:
sudo yum reinstall nvidia-driver-NVML
Ok, please try
cd /var/cuda-repo-10-1-local-10.1.168-418.67/
sudo rpm -ivh --force nvidia-driver-NVML-418.67-4.el7.x86_64.rpm
[root@localhost ~]# cd /var/cuda-repo-10-1-local-10.1.168-418.67/
[root@localhost cuda-repo-10-1-local-10.1.168-418.67]# sudo rpm -ivh --force nvidia-driver-NVML-418.67-4.el7.x86_64.rpm
Préparation… ################################# [100%]
Mise à jour / installation…
1:nvidia-driver-NVML-3:418.67-4.el7################################# [100%]
Does nvidia-smi work now?
yes
[root@localhost cuda-repo-10-1-local-10.1.168-418.67]# nvidia-smi
Tue Sep 17 10:58:33 2019
| NVIDIA-SMI 418.67 Driver Version: 418.67 CUDA Version: 10.1 |
| 0 Tesla K40m Off | 00000000:81:00.0 Off | 0 |
| N/A 27C P8 21W / 235W | 0MiB / 11441MiB | 0% Default |
| 1 Tesla K40m Off | 00000000:87:00.0 Off | 0 |
| N/A 29C P8 22W / 235W | 17MiB / 11441MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 1 11072 G /usr/bin/X 9MiB |
| 1 14364 G /usr/bin/gnome-shell 6MiB |
Everything looks fine now, your application should work.
thank you,
yes my application works correctly
pgfortran -acc -ta=nvidia -fast -Minfo vecAdd.f90 -o vec.out
I return back to you, sorry for taking much time
1 - When I runned nvidia-smi I don’t pay attention for the Persistence-M : OFF (see attachment)
2 - Following a tutorial on the internet, I execute the code once with !$acc directives and once without !$acc directives but I’m surprised ! the excution time is the same
Maybe the accelerators are not functional !
You compiled those with -ta=multicore, so cuda and the gpus are not used at all, everything is done on cpu.
Persistence mode is depreciated, instead the nvidia-persistenced should be configured and started on boot. Please check if it is installed:
sudo systemctl status nvidia-persistenced
[instm@localhost step1]$ sudo systemctl status nvidia-persistenced
[sudo] Mot de passe de instm :
● nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-persistenced.service; disabled; vendor preset: disabled)
Active: inactive (dead)
I change -ta=nvidia (see attachement)
Just run
sudo systemctl enable nvidia-persistenced
sudo systemctl start nvidia-persistenced
to have it running.
Please post the output of
pgaccelinfo
[instm@localhost step1]$ sudo systemctl enable nvidia-persistenced
Created symlink from /etc/systemd/system/multi-user.target.wants/nvidia-persistenced.service to /usr/lib/systemd/system/nvidia-persistenced.service.
[instm@localhost step1]$ sudo systemctl start nvidia-persistenced
[instm@localhost step1]$ pgaccelinfo
CUDA Driver Version: 10010
NVRM version: NVIDIA UNIX x86_64 Kernel Module 418.67 Sat Apr 6 03:07:24 CDT 2019
Device Number: 0
Device Name: Tesla K40m
Device Revision Number: 3.5
Global Memory Size: 11996954624
Number of Multiprocessors: 15
Number of SP Cores: 2880
Number of DP Cores: 960
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 745 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: Yes
Memory Clock Rate: 3004 MHz
Memory Bus Width: 384 bits
L2 Cache Size: 1572864 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
Concurrent Managed Memory: No
PGI Default Target: -ta=tesla:cc35
Device Number: 1
Warp Size: 32
Clock Rate: 745 MHz
Execution Timeout: Yes
ECC Enabled: Yes
Async Engines: 2
Managed Memory: Yes
Everything looks correctly in place and functional.
Do you get better results when omitting -fast optimizations and use -Minfo=accel to get some more info about accelleration used? i.e.
pgfortran -acc -ta=tesla:cc35 -Minfo=accel laplace2d.f90 -o lpc
with acc directives
[instm@localhost step1]$ pgfortran -acc -fast -ta=tesla:cc35 -Minfo=accel laplace2d.f90 -o lpc
laplace:
75, Generating implicit copyout(anew(1:4094,1:4094))
Generating implicit copyin(a(0:4095,0:4095))
76, Loop is parallelizable
77, Loop is parallelizable
Accelerator kernel generated
Generating Tesla code
76, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
77, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
80, Generating implicit reduction(max:error)
90, Generating implicit copyin(anew(1:4094,1:4094))
Generating implicit copyout(a(1:4094,1:4094))
91, Loop is parallelizable
92, Loop is parallelizable
91, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
92, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
[instm@localhost step1]$ time ./lpc
Jacobi relaxation Calculation: 4096 x 4096 mesh
0 0.250000
100 0.002397
200 0.001204
300 0.000804
400 0.000603
500 0.000483
600 0.000403
700 0.000345
800 0.000302
900 0.000269
completed in 84.123 seconds
real 1m24.263s
user 1m17.431s
sys 0m6.841s
without acc directives
0 0.250000
100 0.002397
200 0.001204
300 0.000804
400 0.000603
500 0.000483
600 0.000403
700 0.000345
800 0.000302
900 0.000269
completed in 35.714 seconds
real 0m35.747s
user 0m35.699s
sys 0m0.041s
I told to omit -fast. This is doing cpu optimizations.
[instm@localhost step1]$ pgfortran -acc -ta=nvidia -Minfo=accel laplace2d.f90 -o lpc
0 0.250000
100 0.002397
200 0.001204
300 0.000804
400 0.000603
500 0.000483
600 0.000403
700 0.000345
800 0.000302
900 0.000269
completed in 53.059 seconds
real 0m53.094s
user 0m53.035s
sys 0m0.053s
with acc directives
laplace:
0 0.250000
100 0.002397
200 0.001204
300 0.000804
400 0.000603
500 0.000483
600 0.000403
700 0.000345
800 0.000302
900 0.000269
completed in 84.195 seconds
real 1m24.346s
user 1m17.734s
sys 0m6.616s
Have you an idea what is the problem please ?
No idea, maybe ask at the pgi forums, on the cuda side, everything looks correct.
Maybe also ask here:
[url]CUDA Programming and Performance - NVIDIA Developer Forums
