RunTimeError
I’m using Jetson Nano DevKit 2GB to drive DC motor and ServoMotor with their respective drives.
System was working fine until I downloaded adafruit.
While working on GPIO pins, i’m facing this issue.
RuntimeError: The current user does not have permissions set to access the library functionalites. Please configure permissions or use the root user to run this. It is also possible that /dev/gpiochip0 does not exist. Please check if that file is present.
Hi there and welcome to the NVIDIA developer forums @pradeepkumards81!
This question should better be asked from the experts in the Jetson forums, I will divert your post over there.
Thankyou @MarkusHoHo
your support would helpful.
