You can use TRT to optimize any model file and generate the TRT engine as long as operations in network are supported. Otherwise you might have to create a custom plugin for that particular operation.
Here inference part is handled in “common.py” and data processing (pre-post) can be found in “data_processing.py” file. Pre-processing of the input data will depend on the application & model you are creating.
@SunilJB Thank you very much! The code examples are exactly what I was looking for.
I also wanted to execute the Yolo sample but it returns an error.
File "yolov3_to_onnx.py", line 811, in <module>
main()
File "yolov3_to_onnx.py", line 804, in main
onnx.checker.check_model(yolov3_model_def)
File "/usr/local/lib/python2.7/dist-packages/onnx/checker.py", line 91, in check_model
C.check_model(model.SerializeToString())
onnx.onnx_cpp2py_export.checker.ValidationError: Node (086_upsample) has input size 2 not in range [min=3, max=4].
That is strange 'cause everything is very much “standard”, I mean it uses the same as supposed yolo’s config from the yolo git repo, I haven’t changed the script, I executed it on Jetson nano with JetPack 4.3, etc.
Have I missed something?
Based on the error log, it seems that the “Resize” operation only has two input params, as per the ONNX operation document “Resize” operation should have input size of (3-4). [X : T1, roi : T2, scales : tensor(float), sizes (optional) : tensor(int64)]
Current model just have two input params:
name: “086_upsample” op_type: “Resize” attribute { name: “mode” s: “nearest” type: STRING }
@SunilJB thank you a lot for your help!
Based on your examples I managed to create a simple code which processes data via generated TensorRT engine.
I put the code in case if someone will need it demo_of_processing_via_tensorrt_engine · GitHub
It’s much simpler than the yolo example since it’s based on just mnist )
Could you please elaborate more on the error you are getting in yolov3 samples? Is it the same resize operation issue?
If possible,please share the error log.
Hi! yes, this is the same resize operation issue, still cannot fix it.
I put the whole output of yolov3_to_onnx.py here yolov3_to_onnx_output · GitHub Did you mean this log?
Please let me know if some additional info will be helpful!
As mentioned in earlier post, current “Resize” operation implementation in your model is not as per the ONNX supported operation.
You have to either update your model file or write a custom plugin to handle the customized “Resize” operation.
