This post was a lifesaver!
Thanks for the helpful comment @liuyoungshop
Worked like a charm to get ssd_inception_v2_coco_2018_01_28 working with deepstream SDK SSD example as well.
NOTE: I had to change one thing in the code (missed line I believe) to get it working. simply added in the “Identity” line that was in the original config.py
namespace_plugin_map = {
"MultipleGridAnchorGenerator": PriorBox,
"Postprocessor": NMS,
"Preprocessor": Input,
# "ToFloat": Input,
# "image_tensor": Input,
"MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
"MultipleGridAnchorGenerator/Identity": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf,
namespace_remove = {
"ToFloat",
"image_tensor",
"Preprocessor/map/TensorArrayStack_1/TensorArrayGatherV3",
def preprocess(dynamic_graph):
# remove the unrelated or error layers
dynamic_graph.remove(dynamic_graph.find_nodes_by_path(namespace_remove), remove_exclusive_dependencies=False)
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
# Remove the Squeeze to avoid "Assertion `isPlugin(layerName)' failed"
Squeeze = dynamic_graph.find_node_inputs_by_name(dynamic_graph.graph_outputs[0], 'Squeeze')
dynamic_graph.forward_inputs(Squeeze)
