I am trying to take snapshot from rtsp on jetson tx2, it worked fine.
Command:
gst-launch-1.0 -e rtspsrc location=rtsp://admin:Cms123456@192.168.1.64/h264/ch1/main/av_stream latency=0 ! rtph264depay ! h264parse ! omxh264dec ! nvjpegenc ! multifilesink location=test_%03d.jpeg
I am getting images in the specified directory. This command can capture 20 pictures per second as the rtsp live stream is 20fps. But I want to get picture every 5sec.I think
there are two ways maybe. I can try to change the video rate or add a delay element to the pipeline. I try but failed(I am a newcomer for gstreamer).
Could someone give some advice about these problems, thank you very much!
